Hi.
I have a question about MQX interrupt, is the interrupts with higher priority still valid even with the use of MQX in the application?
If an interrupt is enabled, then a higher priority interrupt comes, then the higher interrupt will be handled ?
Solved! Go to Solution.
Hi David.
Cortex-m4 and MQX support nested interrupt. The high priority interrupt will be handled.
For more details , please refer to MQX user's guide. 3.9 Handling interrupts and exceptions.
Hi David.
