esai 调试数据引脚ESAI_TX2_RX3 无波形输出
Question asked by lou liang on Apr 27, 2019
Latest reply on May 7, 2019 by lou liang
Deal NXP :
软件环境 :Android7.1.1  BSP :kernel 4.10.0
硬件IMX6Q,不使用asrc,只需要esai接口
您好:正在调试IMX6q 的esai audio的放音,现在只用到三个引脚,如下dts配置(已经查了好几遍,没有其他驱动复用这三个引脚),bitclk 和lrclk(44.1K)在用tinyplay播放音乐的时候都有正确的时钟输出,但数据引脚TX2_RX3没有波形变化,在dma完成函数里加打印,也可以看到打印在播放的时候不停地输出。
dts如下:
 dspsi47920_codec: dspsi47920_codec {
                #sound-dai-cells = <0>;
                compatible = "dspsi47920-codec-play";
  sound-si47920-esai {
   compatible ="fsl,imx-audio-si47920";
    model = "imx-si47920";
    esai-controller = <&esai>;
   // asrc-controller = <&asrc>;//not uesd asrc
    audio-codec = <&dspsi47920_codec>;
&esai {
 pinctrl-names = "default";
 pinctrl-0 = <&pinctrl_esai>;
 assigned-clocks = <&clks IMX6QDL_CLK_ESAI_SEL>,
     <&clks IMX6QDL_CLK_ESAI_EXTAL>;
 assigned-clock-parents = <&clks IMX6QDL_CLK_PLL4_AUDIO_DIV>;
 assigned-clock-rates = <722534400>, <22579200>;
 status = "okay";
 fsl,esai-synchronous;
  pinctrl_esai: esaigrp {
   fsl,pins = <
    MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1b030
    MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS    0x1b030
    MX6QDL_PAD_ENET_TXD1__ESAI_TX2_RX3  0x1b030
期待你的尽快回答,已经搁置还几天。非常感谢。
