I tried to initialize the eTPU on MPC 5777C, but the code stopped at fs_memset32() function. and I found the variable value@entry in the function was missing, and it stopped at "*p++ = value;", reporting align 4 IVOR1_Vector: e_b IVOR1_Handler. what is wrong with my initialization.
Thanks !
Hi, could you describe what example is your code based on or how you achieve this result?
