I'm curious about the analog switches used on the I2C buses. Some I2C devices are connected directly to the bus, while a few go thru a switch. Why?
You can check the block diagram of all the components of the kit in this link. I believe you are referring to the NX3L2267, there you will find the data sheet.
Hope it helps!
never-displayed
