Create flexcan configuration for HSRUN with ProcessorExpert
freddy_ben-zeev
When I use ProcessorExpert to configure a flexcan component it seem always to use the clock rate of RUN mode. In order to use flexcan in HSRUN mode it loks like I have to manually calculate how to set the CAN bit rate. Any nicer solution to this?
Freddy
