I migrated the project under keil to linux and compiled it with gcc. The MIMXRT1052xxxxx_flexspi_nor.ld script in sdk2.3 works fine, but it does not work with MIMXRT1052xxxxx_sdram_txt.ld.I uploaded my project, please help me to see it, after the normal download, the serial port will have output, the baud rate is 921600.
Solved! Go to Solution.
Hi wangdong,
Do you try the RT1050 newest SDK code sdk2.5.0?
Which can be downloaded from this link:
Welcome | MCUXpresso SDK Builder
Whether the official code works OK on your side or not?
Kerry
Hi wangdong,
Kerry
