S32K MBD-Toolbox generate code for IAR bug
cg0
Hello,I use matlab 2018b, And I generate code for IAR, I already install the patch.
After generate code, I import the code to IAR for more coding, also I select the "S32K14x.icf" as Linker file. But it always run into fault. Because before I choose the .icf file from matlab, and this situation can run normally.
So, I replace the .icf file, it do works. Then I compare the two .icf file. The matlab generated .icf alway use S32K148 256k flash.icf, no matter what MCU selected.
Labels (2)
Tags (4)
constantinrazva
Hello cg0‌,
Thank you for your investigation! We will make this fix and provide a patch in the S32K Hotfixes page, but we'll do so most probably in May, after the Holidays are over.
Kind regards,
Razvan.
cg0
Hi Razvan
As I know  from https://community.nxp.com/thread/484197, the next version will be released this Q2. Could you tell me will S32K116/118 be added in?
constantinrazva
Hello cg0‌,
Indeed, S32K116/118 will be added in our next release.
Kind regards,
Razvan.
