Kinetis Drivers - fsl_flash versus fsl_ftfx_flash
Question asked by Denis Collis on Apr 19, 2019
Latest reply on Apr 21, 2019 by Kerry Zhou
I see that some of the demos and/or examples use the fsl_flash driver, and others use the fsl_ftfx_flash driiver.  At first glance the APIs look the same.  However, the underlying code is different.  For example, fsl_flash has a mechanism to copy and execute the driver functions from RAM, which is not present in fsl_ftfx_flash.
Which is preferred?
