Regarding the MPC5643L, what is the minimum required for INTC vector table and core exception vector in term of memory alignment boundary value ? In order to set correctly these alignment in linker file.
Pat
Solved! Go to Solution.
See below screen from my linker file:
and a core reference manual:
regards,
Peter
regards,
Peter
Hi petervlna
Does the isr vector table of 2K boundary come from INTC_IACKR_PRC0.INTVEC_PRC0 (9bit) + 'b00' (2bit) = 11bit so 2K boundary ?
Pat
Yes, it is calculated from IACKR
Peter
