s32k148 boot loader
Question asked by Sathish Sekar on Apr 17, 2019
Latest reply on Apr 24, 2019 by Diana Batrlova
Hello All,
I am working on to modify the bootloader / startup sequence for s32k148.
Able to identify the bootloader code, but i required to modify the startup code.
i.e in startupcode I want to select the another bootloader(i require to use multi bootloader, selection is based on switch/jumper settings.)
Could any help me to identify the startupcode to modify?
Startup code files are available in my PC in the following path   ...\Bootloader_Software\S32K148_bootloader\Project_Settings\Startup_Code
But unable to identify the sequence, from where boot loader sequence is called.
NOTE:
I am using windows PC, and installed necessary softwares/ not using linux.
