Shaik Sameem
FCC Test for PN7150
Discussion created by Shaik Sameem on Apr 17, 2019
Latest reply on Apr 25, 2019 by Kan_Li
i am working with PN7150 in our project for NFC. as part of project requirement i am doing FCC testing. for PN7150, i am trying to set Active mode and Standby mode. What should the wave pattern look like an ideal case for Standby mode and Active mode?
We are getting pattern as follows
Active Mode: the following pattern we are observing in the default condition(as per understanding default mode is :Active mode for PN7150). observing these signals continuously after every 20 to 30 seconds if we are keeping the NFC card near to PN7150 chip in a stable position.
Standby Mode: the following pattern  is observed when configuring for Standby mode on PN7150. observing these signals continuously if we are keeping the NFC card near to PN7150 chip in a stable position.
Please kindly let me know the configuration and expected images for Active mode and standby modes.
Thanks & Regards,
Shaik Sameem
