floating-point operation FreeRTOS_10_1_1
zhaoyanling
Hello expert:
I use freeRTOS_10_1_1, and I creat only one task. I get ADC value from ADC12, but when I change the sample into voltage, there is something wrong.
After the following floating-point is comouted,:
 /* Process the result to get the value in volts */
 adcValue = ((float) adcRawValue / adcMax) ;//* (ADC_VREFH - ADC_VREFL);
then the task sleep controlled by follwing command:
 vTaskDelay(pdMS_TO_TICKS(10));
but the task will be never entered. why ?
I don't understand the floating-point operation has relationship with running task.
Could you give me some suggestion?
jiri_kral
can you please share your project? Thanks.
Jiri
zhaoyanling
Hallo Jiri Kral,
Could you check my project? Could you give me some suggestions?
I am eager for your help!
Thank you very much!
zhaoyanling
Dear Jiri Kral,
My project is shown as attachment. and I check the heap size and stack size, shown as the bmp in detail, but it still doesn't work. Could you give me some suggestion?
