Issues with testing alexa and LPC 54018 board
Question asked by Tanmay Parashar on Apr 9, 2019
Latest reply on Apr 9, 2019 by Sabina Bruce
I am working with Alexa, AWS and LPC 54018 module. I have followed the steps as mentioned in the lab document attached here. I have set everything up as mentioned.
I am using Alexa simulator to test the on board LED. Whenever I say " ALEXA ask my home to turn on/off the LED" I get a response which says the LED if OFF in both the cases.
A message like this pops up- " Error retrieving device rendering- The object provided is not a valid template"
I am not understanding where I am going wrong. I have added a few attachments here for your reference.
If you need login credentials at the AWS-Lambda/IOT and Alexa Skills side, I can provide you with those to check what the issue is.
Please help me out.
Thank You!
Warm Regards,
Tanmay
