Error in services launch sequence. PEmicro GDB Launch Failure
Question asked by MinYeop Na on Apr 4, 2019
Latest reply on Apr 4, 2019 by MinYeop Na
Hello.
When downloading s32k118EBV sample code, the following error occurs.
PEmicro GDB Launch Failure : Could not bind socket. Address and port are already in use. Another GDB Server debug session may be using the same Server Port number. To run simultaneous debug sessions, please specify a unique Server Port and GDBMI Port in the Debug Configuration for each project. If another session is not running simultaneously, make sure that the chosen port is available and that pegdbserver_console and the arm-none-eabi-gdb processes have terminated.
Please check attached capture file.
How can I solve this problem???
