Hope you are doing great, can you please send me the link to that AN you mention.
as you can see in the Datasheet and in the application note for TDA8024 it is stated that the TDA8024 is EMV compliant, in AN10141 in section 1 also in datasheet section 2. the one that is not recommended for this is the 8029 it is not compliant anymore for EMVco 4.3c.
please check this references and let me know if this helps.
Jonathan
