When the MPC5744 starts simulation, a power failure causes a verification failure, and the simulation progress remains at 99%. As shown in picture,  Now MPC5744 maintains this state every time it starts simulation. Who can help me solve this problem?
zengs2
yuqf
Could someone do some help for this question? I have met it too.
projectmahi4
what is the simulation tool you are using
zengs2
PE micro
Cyclone FX
When the flash is being erased, the MCU is powered off, which will cause the flash block verification to fail. After the flash is erased through the offline burner, it will become normal. This may be the flash verification protection mechanism of mpc5744 itself
jiri_kral
This issue was probably caused by old PE Micro driver. Did you update it?
https://community.nxp.com/docs/DOC-342273
What is your S32DS Version?
Jiri
