I am using the MPC5744P board with Simulink and Freemaster.
How can I do to measure the processor unit workload?
Also, how can I do to measure the MPC5744P RAM memory use?
Kind Regards, Rafael
Hello ext-rafael.barbosa@chassisbrakes.com,
Unfortunately, we don't have a tool to tell exactly what is the the workload and ram size at a certain point in the code execution.
But, you can check what is the used RAM size by using the arm-none-eabi-size tool and looking to the data and bss memory values. We had a thread before, so please have a look here https://community.nxp.com/message/1103489.
For the workload, well the generated code is executed on a single core so the only thing you can do is to use the profiler blocks in order to measure the execution time either of a function or to measure the execution time between specific program points. In the MBDT toolbox you can find profiler examples that might help you.
Hope this helps,
Marius
