Hi,After my JN516x-EK004 Kit's general extension node downloaded the "DimmerSwitch" program "JN-AN-1219-Zigbee-3-0-Controller-and-Switch-v1007", it always failed to join the supporting IoT gateway through NFC, and the buzzer rang four times in a row. The "decommission device/commission device" of the login iot-gw.nxp web operation cannot be added. But the node suite before downloading this program can be added through NFC. Is this new program not matching, or something else?
Hi Guomiao,
Are you using the JN-AN-1216? Did you look at the 1.4 Network Commissioning JN516x-EK004 Evaluation Kit User Guide?
Could you please provide more details about your issue?
Mario
