I want to evaluate imx6.ulz. As i can understand, i should use imx6.ull evaluation board.
In the migration guide for imx6.ulz, it is written that i shoud use Linux_ 4.14.62_1.0.0 BSP.
There is an new version of the BSP : L4.14.78_1.0.0_MX6UL7D, may y use this one ?
Do you plan a imx6.ulz evaluation board ?
Sincerly,
Christophe
Solved! Go to Solution.
Hi Christophe,
Until now, there are no plans of releasing a different evaluation board for i.MX6ULZ specific. It is supported on i.MX6ULL base board, just replacing the CPU board with the one of i.MX6ULZ processor.
Regarding software and porting guide, this document mentions the mayor considerations when migrating, so, as general guidelines, they should work with newer BSP releases, just considering the changes between BSP versions.
Hope this will be useful for you.
Best regards!
/Carlos
Hi Christophe,
Best regards!
/Carlos
Hi Christophe,
Have you checked AN12264?
https://www.nxp.com/docs/en/nxp/application-notes/AN12264.pdf
Best regards!
/Carlos
Hi Carlos,
I have already read the migration guide.
Thanks for your reply, i will try first the iMX6.ull.
Sincerly,
Christophe
