LinkServer behaviour on uninitialized flash part
Question asked by Satish Acharya on Mar 31, 2019
Latest reply on Apr 9, 2019 by Satish Acharya
I have a Kinetis K60 part with uninitialized flash on a custom board and I’m trying to debug for the first time. I have gone through all the discussions in NXP forum and nothing seems to answer my question below.
Temporarily, I’m using a FREEDOM K64 board as a debugger for my custom board. (I plan to switch to LPC_LINK2 soon. BTW, I get same error message even with LPC_LINK2. So, the debugger is not the issue.) When I try to debug a simple basic project using SWD, the debugger exits with error “Unable to configure core for probe index 1. Wire not connected.”. Redlink Server log has following:
[Started server]
[Connected on port 3025]
redlink> ProbeList
Index = 1
Manufacturer = ARM
Description = DAPLink CMSIS-DAP
VID:PID = 0D28:0204
redlink> ProbeStatus
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireInitialized = FALSE
WireProtocol = JTAG
CoresConfigured = FALSE
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
Probe Type = CMSIS-DAP
Probe Reference Count = 0
redlink> ProbeList
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> ProbeIsOpen 1
FALSE
redlink> ProbeOpenByIndex 1
Probe Handle 1 Open
redlink> WireIsConnected 1
FALSE
redlink> WireSwdConnect 1
Wire Ack Fault - target connected?
redlink> CoresConfigured 1
FALSE
redlink> CoreConfig 1
Wire not connected
[Closed]
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = TRUE
WireProtocol = SWD
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> quit
[Closed]
The log shows the debugger is unable to find K60 core on SWD and this explains the error.
However, interestingly, when I keep reset button on FREEDOM board pressed (so that it resets my custom board and keeps K60 under reset) and try to debug my custom board (of course, I don’t expect it to work but this is an experiment), the debugger is able to detect the core and goes way beyond this point. Here’s the Redlink log with reset pin of FREEDOM board asserted:
[Started server]
redlink> ProbeList
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> ProbeList
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
FALSE
Probe Handle 1 Open
FALSE
DpID = 2BA01477
TRUE
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> quit
[Closed]
The debugger gets DpID and talks to core. As expected, I see saw tooth waveform on reset pin due to WD timer going off. The fact that the debugger is able to talk to core shows electrical issues on SWD pins are ruled out. (I did insert impedance matching/pull-up/pull-down/etc resistors/cap on SWD pins but didn't help.)
Question is why the debugger is unable to talk to core when K60 is NOT under reset? Is it because, core is busy executing/faulting the FF’s from uninitialied flash? If true, why is the debugger not halting the core before attempting to connect? I cannot even do mass erase of the device since SWD is unable to communicate to core.
Any suggestions?
Appreciate your help,
Satish
