What to do best with analog inputs?
nick_jung
Hi, I'm using the MC56F8323VFBE and I'm keen to know what to do best with my unused ANA3-6 inputs? Can I put them on low and pull them to GND to minimize EMI? Cheers from Germany
xiangjun_rong
Hi, Nick,
The ANA3~6 of MC56F8323 are analog input pins, they do not generate EMI signal I think. Anyway, I suggest you connect 5K~10K ohm pull-down resistor for the analog ADC channels pin to protect the chip from high voltage for example ESD voltage.
Hope it can help you
Xiangjun Rong
