disable dualthreading
kesoce
i want to make some timing tests and dont want to have any jitter due to dualthreading. Is it possible to disable it and if, how?
Best regards and thanks for your answers in advance
Tags (2)
alexander_yakov
Please look e6500 Core Reference Manual, Section 2.15.1.2 "Thread Enable (TEN) Register".
This register shows which threads are enabled. By default the only one thread 0 is enabled.
TEN is read-only register, enabling and disabling should be done via TENS and TENC registers.
Direct link to e6500 Core Reference Manual:
https://www.nxp.com/docs/en/reference-manual/E6500RM.pdf
Alexander,
TIC
