FIT and MTBF report of PCA9555DB
zeinabkhademi_k
I am searching for the reliability report for an IC expander with part number: PCA9555DB.
So, may I request you to share failure rate FIT and MTBF report of the component PCA9555DB and  If possible can you also provide any other documents associated with the FIT and reliability such as the total number of samples tested so far, test duration and test temperature details? With considering Activation energy (Ea) = 0.7eV and Confidence Level (CL) = 60% .
Best regards.
Zeinab
fangfang
 Please open a private ticket requesting this information so NXP Quality team can provide you with the requested documentation.
 You may refer to how to open a private ticket as the community document
https://community.nxp.com/docs/DOC-329745.
Hope it help you.
TIC
zeinabkhademi_k
I have received answer for this question.
Your response is appreciated.
Thanks you very much!
Bests
fangfang
hello,
You are welcome
TIC
