How to Use Interrupt for INT_PIT_CH0
mahendra_kumar
Dear Sir,
               I have new using S9KEAN8 microcontroller,I don't know how to use Interrupt in this controller.
I have searched lot of thing but I didn't found any update . Kindly help me regards this.
Thanks Very Much for your kind help.
Mahendra
mahendra.kumar@interfcaeauto.com
kerryzhou
Hi Mahendra Kumar,
   Thank you for the interest in NXP kinetis product, I would like to provide service for you!
    About the PIT interrupt, you can check the KEA8 reference manual:
https://www.nxp.com/docs/en/reference-manual/KEA8RM.pdf
Chapter  Chapter 28 Periodic Interrupt Timer (PIT)
About the code, you can refer to the KE sample code, please check my attachment:
Wish it helps you!
Kerry
