I'm seeking some clarification on section 3.1.17 Device ID.
In this section is lists 7 steps to access the Device ID.
In step 2 it notes "The master sends the Reserved Device ID I2C-bus address followed by the R/W bit set to ‘0’ (write): ‘1111 1000’."
As there is nothing else in the document that explains what the "Reserved Device ID" is, I just wanted to check that I literally have to enter "1111 1000" and it is not "1111 1XXX" table 3 in section 3.1.12 Reserved addresses, where it indicates that XXX can be any value. So a little confused.
I look forward to getting clarification.
Solved! Go to Solution.
Hello Colin Gerrish,
1) explains what the "Reserved Device ID" is.
-> Please have a look at the part of "3.1.17 Device ID"
2) where it indicates that XXX can be any value.
-> It seems X can don't care:
TIC
TIC
