NAND Access in u-boot
jagadiswar_rao
Hi Team,
we are using ls2088a custom board, we are using  NAND and QSPI  are connected to IFC with different chip select .Can we able to access NAND in QSPI-Boot.
ufedor
Please explain how QSPI is connected to IFC (attach corresponding schematics).
jagadiswar_rao
Hi Ufedor,
I have attached the schematic as pdf format of the QSPI connection to IFC.
ufedor
Picture quality is not suitable for inspection - please provide PDF.
ufedor
In the provided schematics only NAND devices are connected to the IFC.
NAND has to be accessible after QSPI boot assuming that RCW with correct signals multiplexing is applied.
jagadiswar_rao
attached a schematic file check this one as a reference.How can we able to access nand on qspi-boot for this.
ufedor
There are no obvious errors in the QSPI_3.pdf.
Sorry, what do you mean?
jagadiswar_rao
required to load kernel on NAND flash from u-boot which is booted from qspi flash.Currently i am using LS2088ardb_qspi_defconfig for compilation of u-boot in this i am not able to access NAND in u-boot prompt.
attaching u-boot logs.
ufedor
There is no hardware issue with the design.
Please create separate question for the U-Boot "nand" issue.
