imx8mq+yocto_4.9.51 Qt examples run failed problem
传策薛
Contributor V
Hi community:
   when I run the qt examples by: ./xx
returns :"Running on a compositor with no screens is not supported", what should I do?
diegoadrian
Probably, you do not have any display assigned. Can you please try using the below Linux command and test again?
$ export DISPLAY=:0
Diego.
传策薛
Contributor V
It is ok now
