How to calibrate the MM9Z1-638 sensor
prathapa_reddy
Please give me the suggestion to calibrate the sensor.If we have any sample code to calibrate the sensor.Please send me the link.I got document says about the calibration procedure.In that they given RUN_IBS_MODULE_CALIBRATION macro in defines.h will enable the calibration option.But  i did not find any file which having name as defines.h
So please guide me to proceed on calibration procedure.And also i want to know about the use of calibration procedure.Please update me the as soon as possible.
TomasVaverka
Hi Prathapreddy,
Unfortunately there is not currently much to share. You can find some information in this thread or by contacting our apps engineer Mr. Wolfgang Bihlmayer.
Tomas
