about ftm_pwm component
zhaoyanling
Dear Expert
I use S32Design Studio for ARM 2018R1, I want to add a ftm_pwm component(flexTimer_pwm) into my project, but there is an error shown as the following. I change the “Deadtime” value from 1 to 63, but the  error always is “Frequency must be different from 0” . Could you help me to work out the error?
thank you very much!
jiri_kral
I'm not sure about your settings - you can look for reference at ftm_pwm example:
Jiri
