source code for proximity_reporter without using RTOS
sforsajith
Dear connection
I am now using QN9080X module. I got example files (zip format ) and I was tried , its work.
but all the examples are using RTOS concept. Its a little complicated to understand and hard to implement in project .Could you please provide the source code for proximity_reporter without using RTOS?
estephania_mart
There are some examples in bare metal in the SDK available, but there is no way to use the  Bluetooth LE application without the OS Abstraction layer due to the dependencies in the libraries and stack management.
I would recommend you to check the Bluetooth LE Application Developer's Guide for a deeper understanding of how it’s the stack working and which are the necessary elements to have it working, you can find the document in the SDK documentation, I would recommend you to check especially the chapter 9.5 RTOS as we do not have those examples without RTOS.
Sorry for the inconveniences this might cause you.
Estephania
