RX FIFO ERROR while both camera streaming
vimalan_93
I am using the linux kernel 4.14.78 from sumo bsp in imx8m EVK (REV-B4) board. I can able to successfully stream the cameras in both minisas connectors individually. But when i tried to stream the both cameras simultaneously i received the RX_FIFO_OVERFLOW error. In NXP release notes they already mentioned about this issue i also attached the screenshot here for your referance. so, Is there any workaround for this issue.
When did you planned to deliver the next release?
vimal.
diegoadrian
Unfortunately, we do not have that type of information. I apologize for the inconveniences this could you.
Diego.
vimalan_93
Hi Diego Adrian Cuevas
I need to use both the cameras simultaneously, but when i tried to do the same i faced this RX_FIFO_OVERFLOW error from one of the camera very frequently. How to solve this issue? Any comments would really helpful for us.
Vimal.
