Hi Yuri ,
I have fused the values in sd card but noe i have changed the board but in this board while I am run the fuse commands to add the values nin bank then the fuse command is aborted , I don't know why ?
Perhaps the issue concerns the fact, that the i.MX fuses may be burned only once.
Yuri
Hello ,
But how to resolve or how can I go forward .
Thanks ,
Pramod
It is not possible to burn the fuses, which were burnt previously.
Only new board should be used.
Yuri.
Dear Yuri ,
How to check that in which bank we have to fuse the values ?
Regards ,
Pramod
