linux-4.9 galcore DMA appears to be stuck at this address
Question asked by Tony Riederer on Mar 22, 2019
Latest reply on Mar 27, 2019 by igorpadykov
GPU lockup in linux 4.9 (yocto/sumo) kernel.
We were previously using the 4.1 (yocto/pyro).
We started seeing this crash on multiple units during long term testing after switching over to sumo.
[294019.051943] **************************
[294019.051952] *** GPU DRV CONFIG ***
[294019.051956] **************************
[294019.051964] Galcore version 6.2.4.150331+fslc
[294019.051969] Galcore options:
[294019.051974] irqLine = 20
[294019.051979] registerMemBase = 0x00130000
[294019.051983] registerMemSize = 0x00004000
[294019.051988] irqLine2D = 21
[294019.051992] registerMemBase2D = 0x00134000
[294019.051996] registerMemSize2D = 0x00004000
[294019.052001] irqLineVG = 22
[294019.052005] registerMemBaseVG = 0x02204000
[294019.052009] registerMemSizeVG = 0x00004000
[294019.052013] contiguousSize = 0x08000000
[294019.052017] contiguousBase = 0x00000000
[294019.052021] externalSize = 0x00000000
[294019.052025] externalBase = 0x00000000
[294019.052029] bankSize = 0x00000000
[294019.052033] fastClear = -1
[294019.052037] compression = 15
[294019.052041] signal = 48
[294019.052045] powerManagement = 1
[294019.052049] baseAddress = 0x10000000
[294019.052053] physSize = 0x80000000
[294019.052057] logFileSize = 0 KB
[294019.052061] recovery = 0
[294019.052065] stuckDump = 0
[294019.052069] gpuProfiler = 0
[294019.052073] irqs =
[294019.052077] -1,
[294019.052081] -1,
[294019.052085] -1,
[294019.052089] -1,
[294019.052094] -1,
[294019.052097] -1,
[294019.052101] -1,
[294019.052104] -1,
[294019.052108] -1,
[294019.052111] -1,
[294019.052118] registerBases =
[294019.052122] 0x00000000,
[294019.052126] 0x00000000,
[294019.052129] 0x00000000,
[294019.052133] 0x00000000,
[294019.052137] 0x00000000,
[294019.052140] 0x00000000,
[294019.052143] 0x00000000,
[294019.052147] 0x00000000,
[294019.052150] 0x00000000,
[294019.052154] 0x00000000,
[294019.052161] registerSizes =
[294019.052165] 0x00000800,
[294019.052168] 0x00000800,
[294019.052172] 0x00000800,
[294019.052176] 0x00000800,
[294019.052180] 0x00000800,
[294019.052183] 0x00000800,
[294019.052187] 0x00000800,
[294019.052190] 0x00000800,
[294019.052194] 0x00000800,
[294019.052197] 0x00000800,
[294019.052204] chipIDs =
[294019.052208] 0xFFFFFFFF,
[294019.052212] 0xFFFFFFFF,
[294019.052217] 0xFFFFFFFF,
[294019.052221] 0xFFFFFFFF,
[294019.052225] 0xFFFFFFFF,
[294019.052228] 0xFFFFFFFF,
[294019.052232] 0xFFFFFFFF,
[294019.052235] 0xFFFFFFFF,
[294019.052239] 0xFFFFFFFF,
[294019.052243] 0xFFFFFFFF,
[294019.052251] Build options:
[294019.052255] gcdGPU_TIMEOUT = 20000
[294019.052259] gcdGPU_2D_TIMEOUT = 20000
[294019.052263] gcdINTERRUPT_STATISTIC = 1
[294019.052270] GPU[8](ChipModel=0x320 ChipRevision=0x5007):
[294019.053751] **************************
[294019.053756] *** GPU STATE DUMP ***
[294019.053761] **************************
[294019.053766] axi = 0x00000050
[294019.053771] idle = 0x7FFFFFFA
[294019.053776] FE not idle
[294019.053780] PE not idle
[294019.053786] DMA appears to be stuck at this address:
[294019.053790] 0xFFFBC920
[294019.053795] dmaLow = 0x48000000
[294019.053800] dmaHigh = 0x00000701
[294019.053805] dmaState = 0x00000815
[294019.053811] command state = 21 (PAR_STALL_ST)
[294019.053817] command DMA state = 0 (CMD_IDLE_ST)
[294019.053823] command fetch state = 2 (FET_VALID_ST)
[294019.053828] DMA request state = 0 (REQ_IDLE_ST)
[294019.053836] cal state = 0 (CAL_IDLE_ST)
[294019.053841] VE request state = 0 (VER_IDLE_ST)
[294019.053845] Debug registers:
[294019.053851] RA[0] debug registers:
[294019.053870] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053886] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053902] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053918] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053935] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053951] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053967] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.053983] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054000] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054016] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054032] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054048] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054064] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054080] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054097] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054113] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054130] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054146] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054163] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054179] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054196] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054212] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054229] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054246] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054262] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054278] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054294] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054310] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054326] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054342] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054358] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054374] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054380] TX[0] debug registers:
[294019.054397] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054414] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054430] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054447] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054462] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054479] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054495] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054511] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054527] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054543] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054559] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054575] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054591] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054607] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054623] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054639] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054645] FE[0] debug registers:
[294019.054662] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054678] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054694] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054710] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054726] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054742] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054777] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054795] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054812] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054829] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054848] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054865] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054884] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054902] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054918] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054935] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054951] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054970] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.054986] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055004] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055020] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055036] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055052] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055068] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055084] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055100] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055116] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055132] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055148] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055164] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055180] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055196] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.055202] PE[0] debug registers:
[294019.055221] [00] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055238] [08] D0000000 00000000 00000000 00001150 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055255] [10] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055272] [18] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055288] [20] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055305] [28] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055321] [30] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055338] [38] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055355] [40] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055371] [48] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055388] [50] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055405] [58] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055421] [60] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055438] [68] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055455] [70] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055472] [78] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055488] [80] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055505] [88] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055521] [90] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055538] [98] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055555] [A0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055572] [A8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055588] [B0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055605] [B8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055622] [C0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055638] [C8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055655] [D0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055672] [D8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055688] [E0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055705] [E8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055721] [F0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055738] [F8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055743] PE[1] debug registers:
[294019.055761] [00] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055778] [08] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055794] [10] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055811] [18] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055828] [20] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055844] [28] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055861] [30] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055878] [38] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055895] [40] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055911] [48] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055928] [50] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055945] [58] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055962] [60] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.055978] [68] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.055995] [70] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056011] [78] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056028] [80] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056045] [88] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056061] [90] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056078] [98] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056095] [A0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056111] [A8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056128] [B0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056144] [B8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056161] [C0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056178] [C8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056194] [D0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056211] [D8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056228] [E0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056244] [E8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056261] [F0] 00000000 00000000 00000000 00000000 A803C4F1 ABCAA5FD BC000086 CDE80512
[294019.056278] [F8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[294019.056284] DE[0] debug registers:
[294019.056301] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056318] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056336] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056352] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056368] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056384] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056400] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056416] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056432] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056448] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056464] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056480] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056496] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056512] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056528] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056544] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056560] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056576] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056592] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056610] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056626] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056642] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056658] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056675] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056691] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056707] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056723] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056739] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056755] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056771] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056787] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056803] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056809] SH[0] debug registers:
[294019.056826] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056842] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056858] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056874] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056890] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056906] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056922] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056938] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056954] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056970] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.056986] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057002] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057018] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057034] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057050] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057068] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057084] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057100] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057116] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057132] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057148] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057164] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057180] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057196] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057212] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057228] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057244] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057260] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057277] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057293] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057309] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057325] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057331] PA[0] debug registers:
[294019.057348] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057364] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057380] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057396] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057412] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057428] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057444] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057460] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057476] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057492] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057507] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057523] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057539] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057556] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057572] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057588] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057604] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057620] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057636] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057652] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057668] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057684] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057700] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057716] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057732] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057748] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057764] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057780] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057797] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057812] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057828] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057844] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057850] SE[0] debug registers:
[294019.057868] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057883] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057899] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057915] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057931] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057947] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057964] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057980] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.057996] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058012] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058028] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058044] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058060] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058076] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058092] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058108] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058124] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058140] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058156] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058172] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058188] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058204] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058220] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058236] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058252] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058268] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058284] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058301] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058317] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058333] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058350] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058366] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.058372] MC[0] debug registers:
[294019.058390] [00] 00000000 00000000 000023A7 00001330 12345678 12345678 12345678 12345678
[294019.058407] [08] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058424] [10] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058440] [18] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058457] [20] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058474] [28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058491] [30] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058508] [38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058524] [40] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058541] [48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058558] [50] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058575] [58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058594] [60] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058611] [68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058627] [70] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058644] [78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058661] [80] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058678] [88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058695] [90] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058713] [98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058730] [A0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058747] [A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058765] [B0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058783] [B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058800] [C0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058817] [C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058833] [D0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058850] [D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058867] [E0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058884] [E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058901] [F0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058917] [F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058922] MC[1] debug registers:
[294019.058940] [00] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058957] [08] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.058974] [10] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.058991] [18] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059007] [20] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059024] [28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059040] [30] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059057] [38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059074] [40] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059091] [48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059107] [50] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059124] [58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059141] [60] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059158] [68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059175] [70] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059192] [78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059208] [80] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059225] [88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059242] [90] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059259] [98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059275] [A0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059292] [A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059309] [B0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059327] [B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059343] [C0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059360] [C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059377] [D0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059394] [D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059410] [E0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059427] [E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059444] [F0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[294019.059461] [F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[294019.059467] HI[0] debug registers:
[294019.059485] [00] 000008BC 000010CA 00000B6D AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059502] [08] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059519] [10] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059537] [18] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059554] [20] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059570] [28] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059587] [30] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059604] [38] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059621] [40] 00000001 00000001 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059638] [48] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059655] [50] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059672] [58] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059689] [60] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059706] [68] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059723] [70] 00000001 00000001 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059740] [78] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059756] [80] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059773] [88] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059790] [90] 00000001 00000001 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059807] [98] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059824] [A0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059841] [A8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059858] [B0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059875] [B8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059891] [C0] 00000001 00000001 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059908] [C8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059925] [D0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059942] [D8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059959] [E0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059976] [E8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.059993] [F0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.060010] [F8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[294019.060016] TPG[1] debug registers:
[294019.060033] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060049] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060065] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060082] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060089] TFB[1] debug registers:
[294019.060107] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060123] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060139] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060155] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060161] USC[1] debug registers:
[294019.060179] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060195] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060211] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060227] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060243] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060259] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060275] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060291] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060297] L2[0] debug registers:
[294019.060314] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060330] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060346] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060364] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060380] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060396] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060412] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060428] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060444] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060460] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060476] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060492] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060509] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060525] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060540] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060557] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060573] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060589] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060605] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060621] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060637] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060653] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060669] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060685] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060700] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060717] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060733] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060749] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060764] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060781] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060797] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060813] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060819] BLT[0] debug registers:
[294019.060836] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060852] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060868] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060884] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060900] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060916] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060932] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060948] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060964] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060980] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.060997] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061013] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061030] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061045] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061061] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061077] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061093] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061109] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061126] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061142] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061158] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061174] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061190] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061206] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061222] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061238] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061254] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061270] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061286] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061303] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061319] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061335] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061342] Other Registers[0]:
[294019.061349] [0x0040] 0x000023A7
[294019.061355] [0x0044] 0x00001330
[294019.061361] [0x004C] 0x00000998
[294019.061366] [0x0050] 0x00000340
[294019.061374] [0x0054] 0x00000340
[294019.061379] [0x0058] 0x00000AA7
[294019.061385] [0x005C] 0x00000860
[294019.061390] [0x0060] 0x00000540
[294019.061396] [0x043C] 0x00000000
[294019.061402] [0x0440] 0x20000000
[294019.061407] [0x0444] 0x00000000
[294019.061413] [0x0414] 0x3C000000
[294019.061418] [0x0100] 0x00140021
[294019.061423] Other Registers[1]:
[294019.061430] [0x0040] 0x000023A7
[294019.061435] [0x0044] 0x00001330
[294019.061441] [0x004C] 0x00000998
[294019.061446] [0x0050] 0x00000340
[294019.061452] [0x0054] 0x00000340
[294019.061457] [0x0058] 0x00000AA7
[294019.061463] [0x005C] 0x00000860
[294019.061468] [0x0060] 0x00000540
[294019.061474] [0x043C] 0x00000000
[294019.061480] [0x0440] 0x20000000
[294019.061485] [0x0444] 0x00000000
[294019.061491] [0x0414] 0x3C000000
[294019.061496] [0x0100] 0x00140021
[294019.061590] PRE_STACK:
[294019.061597] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061604] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061611] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061617] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061624] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061630] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061637] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061645] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061774] CMD_STACK:
[294019.061780] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061787] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061793] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061800] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061806] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061813] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061819] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061826] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061830] LINK_STACK:
[294019.061836] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061843] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061898] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061907] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061914] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061921] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061933] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061940] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[294019.061944] **************************
[294019.061949] ***** SW COUNTERS *****
[294019.061953] **************************
[294019.061958] Execute Count = 0x00007C59
[294019.061963] Execute Addr = 0xFFFFF130
[294019.061967] End Addr = 0xFFFFF120
[294019.061982] CPU: 1 PID: 18888 Comm: kworker/u8:3 Tainted: P O 4.9.88-1.0.0-ga+yocto+g46f9b57 #1
[294019.061987] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[294019.062086] Workqueue: galcore workqueue _TimerFunction [galcore]
[294019.062097] Backtrace:
[294019.062127] [<8010bb80>] (dump_backtrace) from [<8010be58>] (show_stack+0x18/0x1c)
[294019.062137] r7:20010013 r6:80b18f30 r5:00000000 r4:80b18f30
[294019.062151] [<8010be40>] (show_stack) from [<8039a464>] (dump_stack+0x80/0x94)
[294019.062210] [<8039a3e4>] (dump_stack) from [<7f0062cc>] (gckOS_DumpCallStack+0x10/0x18 [galcore])
[294019.062220] r7:ceb3de00 r6:7f039354 r5:7f035980 r4:00000000
[294019.062308] [<7f0062bc>] (gckOS_DumpCallStack [galcore]) from [<7f02a26c>] (gckHARDWARE_DumpGPUState+0x858/0xa14 [galcore])
[294019.062389] [<7f029a14>] (gckHARDWARE_DumpGPUState [galcore]) from [<7f00d394>] (_DumpState+0x18/0x34 [galcore])
[294019.062404] r10:80b02d00 r9:00000000 r8:00000000 r7:cef4b000 r6:ceb59e00 r5:ceb3de00
[294019.062409] r4:ceb59e00
[294019.062489] [<7f00d37c>] (_DumpState [galcore]) from [<7f00e2e0>] (gckKERNEL_Recovery+0x114/0x150 [galcore])
[294019.062496] r5:ceb3de00 r4:ceb59e00
[294019.062576] [<7f00e1cc>] (gckKERNEL_Recovery [galcore]) from [<7f00e4d4>] (_MonitorTimerFunction+0x1b8/0x1c8 [galcore])
[294019.062585] r7:00002710 r6:00000001 r5:00000002 r4:ceb59e00
[294019.062661] [<7f00e31c>] (_MonitorTimerFunction [galcore]) from [<7f002398>] (_TimerFunction+0x18/0x1c [galcore])
[294019.062670] r7:ce94ca00 r6:ce002800 r5:ced40180 r4:ce81e4c0
[294019.062719] [<7f002380>] (_TimerFunction [galcore]) from [<8013d110>] (process_one_work+0x1dc/0x3f8)
[294019.062732] [<8013cf34>] (process_one_work) from [<8013e014>] (worker_thread+0x68/0x5c0)
[294019.062745] r10:80b02d00 r9:00000088 r8:ffffe000 r7:ce002818 r6:ced40198 r5:ce002800
[294019.062750] r4:ced40180
[294019.062762] [<8013dfac>] (worker_thread) from [<80143214>] (kthread+0x110/0x118)
[294019.062772] r10:00000000 r9:00000000 r8:8013dfac r7:ced40180 r6:cffda000 r5:cff1fd40
[294019.062777] r4:00000000
[294019.062790] [<80143104>] (kthread) from [<80107e30>] (ret_from_fork+0x14/0x24)
[294019.062799] r8:00000000 r7:00000000 r6:00000000 r5:80143104 r4:cff1fd40
[294019.062808] **************************
[294019.062813] **** COMMAND BUF DUMP ****
[294019.062817] **************************
[294019.062822] Submitted commit stamp = 24840
[294019.062827] Executed commit stamp = 24839
[294019.062835] DMA Address 0xFFFBC920, memory around:
[294019.062855] User Command Buffer:
[294019.062865] FFFBC000 : 000C060C 00000000 000C0521 00008A04 000C0521 00000EE6 3F0C0921 00000001
[294019.062877] FFFBC020 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.062885] FFFBC040 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.062894] FFFBC060 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.062902] FFFBC080 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.062910] FFFBC0A0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000403EC
[294019.062918] FFFBC0C0 : 0024040B FFFFFF82 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.062926] FFFBC0E0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004040D
[294019.062934] FFFBC100 : 0020001F FFFFDF41 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.062942] FFFBC120 : 00001400 00000500 06000006 FFFFFFF0 08010E03 00000008 080104AE 00000320
[294019.062951] FFFBC140 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.062959] FFFBC160 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFD619 000403EC 0024040B
[294019.062967] FFFBC180 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.062975] FFFBC1A0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.062983] FFFBC1C0 : 48000000 00000701 18000000 00000000 18000000 00000000 18000000 FFFFE3A0
[294019.062993] FFFBC1E0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063001] FFFBC200 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063012] FFFBC220 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063020] FFFBC240 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063028] FFFBC260 : 18000000 00000000 18000000 00000000 18000000 00000000 08010E00 00000001
[294019.063036] FFFBC280 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063044] FFFBC2A0 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.063054] FFFBC2C0 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.063062] FFFBC2E0 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.063070] FFFBC300 : 080104B1 00000000 080104B8 00000000 08020498 002403EC 00280498 00000000
[294019.063080] FFFBC320 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.063088] FFFBC340 : 08010497 0030CCCC 080104B3 00000000 08020484 0024040D 000400AC 00000000
[294019.063096] FFFBC360 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.063104] FFFBC380 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.063112] FFFBC3A0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.063120] FFFBC3C0 : 0801048D A0002006 20000100 FFFFFF64 002403EC 00280498 08010001 00000000
[294019.063128] FFFBC3E0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.063138] FFFBC400 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.063146] FFFBC420 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.063154] FFFBC440 : 18000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063162] FFFBC460 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063171] FFFBC480 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063179] FFFBC4A0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063187] FFFBC4C0 : 18000000 00000000 18000000 00000000 40000006 FFFFF090 18000000 5A900000
[294019.063195] FFFBC4E0 : 18000000 00000500 18000000 00000500 18000000 00000008 08010E00 00000001
[294019.063203] FFFBC500 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063211] FFFBC520 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.063219] FFFBC540 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.063227] FFFBC560 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.063237] FFFBC580 : 080104B1 00000000 080104B8 00000000 08020498 0004049F 002404B5 00000000
[294019.063246] FFFBC5A0 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.063254] FFFBC5C0 : 08010497 0030CCCC 080104B3 00000000 08020484 000404A4 00200016 00000000
[294019.063262] FFFBC5E0 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.063270] FFFBC600 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.063278] FFFBC620 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.063286] FFFBC640 : 0801048D A0002006 20000100 FFFFFF64 0004049F 002404B5 08010001 00000000
[294019.063294] FFFBC660 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.063302] FFFBC680 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.063310] FFFBC6A0 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.063318] FFFBC6C0 : 18000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063326] FFFBC6E0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063334] FFFBC700 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063343] FFFBC720 : 18000000 00000000 18000000 FFFFF7C8 18000000 00000000 18000000 00000000
[294019.063351] FFFBC740 : 18000000 00000000 18000000 00000000 40000002 FFFFF0F0 18000000 5A900000
[294019.063360] FFFBC760 : 18000000 00000500 18000000 00000500 18000000 00000008 08010E00 00000001
[294019.063368] FFFBC780 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063376] FFFBC7A0 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.063383] FFFBC7C0 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.063391] FFFBC7E0 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.063399] FFFBC800 : 080104B1 00000000 080104B8 00000000 08020498 00040483 00240494 00000000
[294019.063407] FFFBC820 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.063416] FFFBC840 : 08010497 0030CCCC 080104B3 00000000 08020484 0004048E 00200011 00000000
[294019.063424] FFFBC860 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.063432] FFFBC880 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.063440] FFFBC8A0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.063448] FFFBC8C0 : 0801048D A0002006 20000100 FFFFFF64 00040483 00240494 08010001 00000000
[294019.063456] FFFBC8E0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.063464] FFFBC900 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.063474] FFFBC920 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.063482] FFFBC940 : 18000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063490] FFFBC960 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063498] FFFBC980 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.063507] FFFBC9A0 : 18000000 00000000 18000000 FFFFE4A0 18000000 00000000 18000000 00000000
[294019.063515] FFFBC9C0 : 18000000 00000053 18000000 0000017F 40000008 FFFFF140 18000000 5A900000
[294019.063523] FFFBC9E0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000004 FFFFFB60
[294019.063531] FFFBCA00 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063540] FFFBCA20 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.063548] FFFBCA40 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.063556] FFFBCA60 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.063563] FFFBCA80 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.063573] FFFBCAA0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040480
[294019.063581] FFFBCAC0 : 00240494 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.063589] FFFBCAE0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040473
[294019.063597] FFFBCB00 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.063605] FFFBCB20 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.063613] FFFBCB40 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.063624] FFFBCB60 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040480 00240494
[294019.063634] FFFBCB80 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.063642] FFFBCBA0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.063650] FFFBCBC0 : 48000000 00000701 18000000 C3C2C1C0 18000000 CBCAC9C8 18000000 D3D2D1D0
[294019.063659] FFFBCBE0 : 18000000 DBDAD9D8 18000000 E3E2E1E0 18000000 EBEAE9E8 18000000 F3F2F1F0
[294019.063667] FFFBCC00 : 18000000 FBFAF9F8 18000000 03020100 18000000 0B0A0908 18000000 13121110
[294019.063676] FFFBCC20 : 18000000 1B1A1918 18000000 FFFFE4F0 18000000 2B2A2928 18000000 33323130
[294019.063684] FFFBCC40 : 18000000 3B3A3938 18000000 63626140 18000000 00000001 18000000 5A900000
[294019.063694] FFFBCC60 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFFBC0
[294019.063702] FFFBCC80 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063710] FFFBCCA0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.063718] FFFBCCC0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.063726] FFFBCCE0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.063734] FFFBCD00 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.063742] FFFBCD20 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049B
[294019.063753] FFFBCD40 : 002404B5 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.063762] FFFBCD60 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040494
[294019.063770] FFFBCD80 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.063778] FFFBCDA0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.063787] FFFBCDC0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.063795] FFFBCDE0 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004049B 002404B5
[294019.063802] FFFBCE00 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.063812] FFFBCE20 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.063820] FFFBCE40 : 48000000 00000701 18000000 00000080 18000000 01010100 18000000 00000000
[294019.063828] FFFBCE60 : 18000000 00000000 18000000 00000001 18000000 80808080 18000000 1C1C1C1C
[294019.063837] FFFBCE80 : 18000000 00001C1C 18000000 1A1A1A00 18000000 12121212 18000000 12121212
[294019.063845] FFFBCEA0 : 18000000 80121212 18000000 FFFFFA20 18000000 12121212 18000000 12121212
[294019.063853] FFFBCEC0 : 18000000 80121212 18000000 00000000 18000000 00000001 18000000 5A900000
[294019.063861] FFFBCEE0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000006 FFFFFC10
[294019.063869] FFFBCF00 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.063878] FFFBCF20 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.063888] FFFBCF40 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.063896] FFFBCF60 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.063904] FFFBCF80 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.063912] FFFBCFA0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049A
[294019.063920] FFFBCFC0 : 002404BA 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.063928] FFFBCFE0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040495
[294019.063943] Dump Level is 2, dump 64 valid record in link queue:
[294019.063959] User Command Buffer: 40000099, FFFF22F8 PID:822 Xorg
[294019.063971] FFFF22F8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.063979] FFFF2318 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.063987] FFFF2338 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.063995] FFFF2358 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.064003] FFFF2378 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0000040D
[294019.064011] FFFF2398 : 000404B9 0030CCCC 080204BA FFFFFFFF FFFFFFFF 002403EC 080104B5 00000000
[294019.064019] FFFF23B8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000003EC
[294019.064029] FFFF23D8 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.064037] FFFF23F8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.064045] FFFF2418 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.064053] FFFF2438 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0000040D 000404B9
[294019.064061] FFFF2458 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.064069] FFFF2478 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.064077] FFFF2498 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064085] FFFF24B8 : 18000000 00000701 18000000 00000701 18000000 EBFFFFFE 18000000 E3000000
[294019.064094] FFFF24D8 : 18000000 FFFFE730 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.064102] FFFF24F8 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.064110] FFFF2518 : 18000000 00000500 18000000 00000008 18000000 FFFFF0F8 18000000 FFFFFDC7
[294019.064118] FFFF2538 : 18000000 00000000 18000000 00000000 18000000 00000000 08010E00 00000001
[294019.064126] FFFF2558 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.064134] FFFF2578 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.064142] FFFF2598 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.064150] FFFF25B8 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.064158] FFFF25D8 : 080104B1 00000000 080104B8 00000000 08020498 0024040D 002804B9 00000000
[294019.064166] FFFF25F8 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.064174] FFFF2618 : 08010497 0030CCCC 080104B3 00000000 08020484 002403EC 000400AC 00000000
[294019.064183] FFFF2638 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.064191] FFFF2658 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.064199] FFFF2678 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.064209] FFFF2698 : 0801048D A0002006 20000100 FFFFFF64 0024040D 002804B9 08010001 00000000
[294019.064217] FFFF26B8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.064225] FFFF26D8 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.064233] FFFF26F8 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.064241] FFFF2718 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064249] FFFF2738 : 18000000 00000701 18000000 00000701 18000000 11C520B0 18000000 E59433BC
[294019.064257] FFFF2758 : 18000000 FFFFE780 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.064265] FFFF2778 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.064275] FFFF2798 : 18000000 00000500 18000000 00000008 40000003 FFFFFE68
[294019.064290] User Command Buffer: 4000004E, FFFF27D0 PID:822 Xorg
[294019.064300] FFFF27D0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.064308] FFFF27F0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.064316] FFFF2810 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.064324] FFFF2830 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.064332] FFFF2850 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040411
[294019.064340] FFFF2870 : 00240431 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.064348] FFFF2890 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000403F0
[294019.064356] FFFF28B0 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.064367] FFFF28D0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.064375] FFFF28F0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.064383] FFFF2910 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040411 00240431
[294019.064392] FFFF2930 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.064400] FFFF2950 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.064408] FFFF2970 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064416] FFFF2990 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.064425] FFFF29B0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E59434F8
[294019.064433] FFFF29D0 : 18000000 E1D530B4 18000000 FFFFE7D0 18000000 5A900000 18000000 00000500
[294019.064441] FFFF29F0 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.064449] FFFF2A10 : 18000000 00000500 18000000 00000500 18000000 00000008 40000009 FFFFFEB8
[294019.064464] User Command Buffer: 4000004E, FFFF2A50 PID:822 Xorg
[294019.064472] FFFF2A50 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.064484] FFFF2A70 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.064492] FFFF2A90 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.064500] FFFF2AB0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.064508] FFFF2AD0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004044B
[294019.064516] FFFF2AF0 : 00240452 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.064524] FFFF2B10 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040431
[294019.064532] FFFF2B30 : 00200007 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.064540] FFFF2B50 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.064550] FFFF2B70 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.064558] FFFF2B90 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004044B 00240452
[294019.064566] FFFF2BB0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.064575] FFFF2BD0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.064583] FFFF2BF0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064591] FFFF2C10 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.064600] FFFF2C30 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E58D7000
[294019.064610] FFFF2C50 : 18000000 E12FFF38 18000000 FFFFE820 18000000 5A900000 18000000 00000500
[294019.064618] FFFF2C70 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.064627] FFFF2C90 : 18000000 00000500 18000000 00000500 18000000 00000008 40000007 FFFFFF08
[294019.064643] User Command Buffer: 4000004E, FFFF2CD0 PID:822 Xorg
[294019.064651] FFFF2CD0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.064660] FFFF2CF0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.064668] FFFF2D10 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.064676] FFFF2D30 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.064684] FFFF2D50 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040466
[294019.064692] FFFF2D70 : 00240473 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.064702] FFFF2D90 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040452
[294019.064710] FFFF2DB0 : 0020000D 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.064718] FFFF2DD0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.064727] FFFF2DF0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.064737] FFFF2E10 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040466 00240473
[294019.064744] FFFF2E30 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.064752] FFFF2E50 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.064761] FFFF2E70 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064769] FFFF2E90 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.064777] FFFF2EB0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E1A0000A
[294019.064785] FFFF2ED0 : 18000000 E59433B0 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.064794] FFFF2EF0 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.064802] FFFF2F10 : 18000000 00000000 18000000 00000000 18000000 00000000 40000005 FFFFFF58
[294019.064815] User Command Buffer: 4000004E, FFFF2F50 PID:822 Xorg
[294019.064825] FFFF2F50 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.064833] FFFF2F70 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.064841] FFFF2F90 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.064850] FFFF2FB0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.064858] FFFF2FD0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040480
[294019.064866] FFFF2FF0 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.064877] FFFF3010 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040473
[294019.064885] FFFF3030 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.064893] FFFF3050 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.064901] FFFF3070 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.064911] FFFF3090 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040480 00240494
[294019.064918] FFFF30B0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.064927] FFFF30D0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.064935] FFFF30F0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.064943] FFFF3110 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.064951] FFFF3130 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E1A01000
[294019.064959] FFFF3150 : 18000000 E12FFF33 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.064967] FFFF3170 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.064977] FFFF3190 : 18000000 00000000 18000000 00000000 18000000 00000000 40000003 FFFFFFA8
[294019.064990] User Command Buffer: 4000004E, FFFF31D0 PID:822 Xorg
[294019.064998] FFFF31D0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065007] FFFF31F0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065016] FFFF3210 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065023] FFFF3230 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065033] FFFF3250 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049B
[294019.065041] FFFF3270 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.065049] FFFF3290 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040494
[294019.065057] FFFF32B0 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065065] FFFF32D0 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.065073] FFFF32F0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065081] FFFF3310 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049B 002404B5
[294019.065089] FFFF3330 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065099] FFFF3350 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.065107] FFFF3370 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.065115] FFFF3390 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.065124] FFFF33B0 : 18000000 FFFFE8D0 18000000 00000701 18000000 00000701 18000000 E50B304C
[294019.065132] FFFF33D0 : 18000000 E3A010C0 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.065140] FFFF33F0 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.065148] FFFF3410 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFE010
[294019.065160] Context Buffer: 00000000, 00000000 PID:18879 kworker/u8:2
[294019.065168] FFFFC000 : 08010E02 00000701 48000000 00000701 08010594 00000001 08015311 00000000
[294019.065175] FFFFC020 : 08010E02 00000701 48000000 00000701 10000000 00000000
[294019.065186] User Command Buffer: 4000004E, FFFF3450 PID:822 Xorg
[294019.065195] FFFF3450 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065203] FFFF3470 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065211] FFFF3490 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065221] FFFF34B0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065229] FFFF34D0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049A
[294019.065237] FFFF34F0 : 002404BA 00000320 080204BA FFFFFFFF FFFFFFFF FFFFFF64 080104B5 00000000
[294019.065246] FFFF3510 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040495
[294019.065254] FFFF3530 : 00200020 00240452 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065262] FFFF3550 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.065270] FFFF3570 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065279] FFFF3590 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004049A 002404BA
[294019.065286] FFFF35B0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065298] FFFF35D0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.065306] FFFF35F0 : 48000000 00000701 18000000 000404B9 18000000 00000000 18000000 00000000
[294019.065315] FFFF3610 : 18000000 00000000 18000000 00000008 18000000 00000701 18000000 00000701
[294019.065323] FFFF3630 : 18000000 FFFFE920 18000000 00000701 18000000 00000701 18000000 0A00007D
[294019.065331] FFFF3650 : 18000000 E51B104C 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.065339] FFFF3670 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.065347] FFFF3690 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFE070
[294019.065360] User Command Buffer: 4000004E, FFFF36D0 PID:822 Xorg
[294019.065369] FFFF36D0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065377] FFFF36F0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065385] FFFF3710 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065393] FFFF3730 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065400] FFFF3750 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004047F
[294019.065409] FFFF3770 : 0024049F 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.065418] FFFF3790 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040474
[294019.065426] FFFF37B0 : 00200020 00240473 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065434] FFFF37D0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.065442] FFFF37F0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065450] FFFF3810 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004047F 0024049F
[294019.065458] FFFF3830 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065467] FFFF3850 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.065475] FFFF3870 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.065483] FFFF3890 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.065491] FFFF38B0 : 18000000 FFFFE970 18000000 00000701 18000000 00000701 18000000 E5933010
[294019.065499] FFFF38D0 : 18000000 E51B005C 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.065507] FFFF38F0 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.065516] FFFF3910 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFE0C0
[294019.065529] User Command Buffer: 4000004E, FFFF3950 PID:822 Xorg
[294019.065538] FFFF3950 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065546] FFFF3970 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065554] FFFF3990 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065561] FFFF39B0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065570] FFFF39D0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040463
[294019.065578] FFFF39F0 : 00240483 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.065587] FFFF3A10 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040453
[294019.065595] FFFF3A30 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065603] FFFF3A50 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.065612] FFFF3A70 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065620] FFFF3A90 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040463 00240483
[294019.065628] FFFF3AB0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065636] FFFF3AD0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.065644] FFFF3AF0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.065652] FFFF3B10 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.065661] FFFF3B30 : 18000000 FFFFE9D0 18000000 00000701 18000000 00000701 18000000 EAFFFF8D
[294019.065669] FFFF3B50 : 18000000 E51B0074 18000000 FFFFE348 18000000 5A900000 18000000 00000500
[294019.065678] FFFF3B70 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.065687] FFFF3B90 : 18000000 00000500 18000000 00000500 18000000 00000008 40000004 FFFFE120
[294019.065700] User Command Buffer: 4000004E, FFFF3BD0 PID:822 Xorg
[294019.065710] FFFF3BD0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065718] FFFF3BF0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065726] FFFF3C10 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065734] FFFF3C30 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065742] FFFF3C50 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040448
[294019.065750] FFFF3C70 : 00240468 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.065758] FFFF3C90 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040432
[294019.065766] FFFF3CB0 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065774] FFFF3CD0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.065782] FFFF3CF0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065790] FFFF3D10 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040448 00240468
[294019.065798] FFFF3D30 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065806] FFFF3D50 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.065814] FFFF3D70 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.065822] FFFF3D90 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.065831] FFFF3DB0 : 18000000 FFFFEA30 18000000 00000701 18000000 00000701 18000000 EBFFFFFE
[294019.065841] FFFF3DD0 : 18000000 EAFFFFE8 18000000 FFFFEF70 18000000 5A900000 18000000 00000500
[294019.065849] FFFF3DF0 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.065857] FFFF3E10 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFE170
[294019.065878] User Command Buffer: 4000004E, FFFF3E50 PID:822 Xorg
[294019.065889] FFFF3E50 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.065898] FFFF3E70 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.065905] FFFF3E90 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.065913] FFFF3EB0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.065923] FFFF3ED0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004042C
[294019.065931] FFFF3EF0 : 0024044C 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.065939] FFFF3F10 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040411
[294019.065948] FFFF3F30 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.065956] FFFF3F50 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.065964] FFFF3F70 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.065975] FFFF3F90 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004042C 0024044C
[294019.065984] FFFF3FB0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.065992] FFFF3FD0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.066000] FFFF3FF0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.066008] FFFF4010 : 18000000 00000701 18000000 00000701 18000000 E59000A0 18000000 E0006FC0
[294019.066016] FFFF4030 : 18000000 FFFFEA90 18000000 E51B305C 18000000 13A03001 18000000 EAFFFF98
[294019.066024] FFFF4050 : 18000000 EAFFFF3A 18000000 FFFFFC50 18000000 5A900000 18000000 00000500
[294019.066032] FFFF4070 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.066040] FFFF4090 : 18000000 00000500 18000000 00000500 18000000 00000008 40000006 FFFFE1D0
[294019.066056] User Command Buffer: 400000E6, FFFF40D0 PID:822 Xorg
[294019.066065] FFFF40D0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.066075] FFFF40F0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.066083] FFFF4110 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.066091] FFFF4130 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.066099] FFFF4150 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000003EC
[294019.066108] FFFF4170 : 00040498 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.066116] FFFF4190 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0000040D
[294019.066125] FFFF41B0 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.066133] FFFF41D0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.066141] FFFF41F0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.066150] FFFF4210 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 000003EC 00040498
[294019.066157] FFFF4230 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.066167] FFFF4250 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.066175] FFFF4270 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.066184] FFFF4290 : 18000000 00000701 18000000 00000701 18000000 E24CB004 18000000 E1C141DC
[294019.066192] FFFF42B0 : 18000000 FFFFEAE0 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.066200] FFFF42D0 : 18000000 00000008 18000000 FFFFE730 18000000 5A900000 18000000 00000500
[294019.066208] FFFF42F0 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.066216] FFFF4310 : 18000000 00000500 18000000 00000500 18000000 00000008 08010E00 00000001
[294019.066224] FFFF4330 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.066235] FFFF4350 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.066243] FFFF4370 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.066253] FFFF4390 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.066261] FFFF43B0 : 080104B1 00000000 080104B8 00000000 08020498 000403EC 0024040B 0030CCCC
[294019.066269] FFFF43D0 : 080204BA FFFFFFFF FFFFFFFF 0024040D 080104B5 00000000 080104B6 FFFFF6FF
[294019.066277] FFFF43F0 : 08010497 0030CCCC 080104B3 00000000 08020484 0004040D 0020001F 00000000
[294019.066285] FFFF4410 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.066293] FFFF4430 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.066302] FFFF4450 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.066310] FFFF4470 : 0801048D A0002006 20000100 00000008 000403EC 0024040B 08010001 00000000
[294019.066319] FFFF4490 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.066327] FFFF44B0 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.066335] FFFF44D0 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.066344] FFFF44F0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 FFFFEC10
[294019.066352] FFFF4510 : 18000000 00000701 18000000 00000701 18000000 EBFFFFFE 18000000 E3500001
[294019.066360] FFFF4530 : 18000000 FFFFEB30 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.066368] FFFF4550 : 18000000 00000008 18000000 FFFFF478 18000000 5A900000 18000000 00000500
[294019.066376] FFFF4570 : 18000000 00000500 18000000 00000008 08010E00 00000001 0803048A 5A900000
[294019.066384] FFFF4590 : 00001400 00000500 080104E8 00000500 08010E03 00000008 080104AD 00000320
[294019.066392] FFFF45B0 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 08014A98 00000000
[294019.066400] FFFF45D0 : 08014A99 00000000 08014A9A 00000000 08014A9B 00000000 08014A9C 00000000
[294019.066408] FFFF45F0 : 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000 080104B1 00000000
[294019.066416] FFFF4610 : 080104B8 00000000 08020498 002403EC 00280498 00000000 080204BA FFFFFFFF
[294019.066424] FFFF4630 : FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
[294019.066431] FFFF4650 : 080104B3 00000000 08020484 0024040D 000400AC 00000000 08014A60 00000500
[294019.066441] FFFF4670 : 080104C0 00000000 08040480 5A900000 00001400 00000500 06000006 00000000
[294019.066449] FFFF4690 : 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8 080104B6 FFFFFF64
[294019.066457] FFFF46B0 : 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF 0801048D A0002006
[294019.066468] FFFF46D0 : 20000100 FFFFFF64 002403EC 00280498 08010001 00000000 08010001 00000000
[294019.066476] FFFF46F0 : 08010001 00000000 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.066484] FFFF4710 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 00000701
[294019.066492] FFFF4730 : 18000000 00000701 18000000 00000008 18000000 00000701 18000000 00000701
[294019.066500] FFFF4750 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.066508] FFFF4770 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 FFFFEC60
[294019.066517] FFFF4790 : 18000000 00000701 18000000 00000701 18000000 E5D33004 18000000 03A03001
[294019.066525] FFFF47B0 : 18000000 FFFFEB80 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.066532] FFFF47D0 : 18000000 00000008 40000004 FFFFE220
[294019.066546] User Command Buffer: 40000050, FFFF4800 PID:822 Xorg
[294019.066555] FFFF4800 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.066563] FFFF4820 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.066571] FFFF4840 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.066579] FFFF4860 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.066587] FFFF4880 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049F
[294019.066595] FFFF48A0 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.066603] FFFF48C0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000404A4
[294019.066611] FFFF48E0 : 00200016 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.066619] FFFF4900 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.066627] FFFF4920 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.066636] FFFF4940 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049F 002404B5
[294019.066644] FFFF4960 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.066652] FFFF4980 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.066660] FFFF49A0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.066669] FFFF49C0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.066676] FFFF49E0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.066686] FFFF4A00 : 18000000 00000701 18000000 FFFFECB0 18000000 00000701 18000000 00000701
[294019.066694] FFFF4A20 : 18000000 E24B403C 18000000 EBFFF3BC 18000000 FFFFEBD0 18000000 5A900000
[294019.066702] FFFF4A40 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFE270
[294019.066716] User Command Buffer: 40000050, FFFF4A80 PID:822 Xorg
[294019.066725] FFFF4A80 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.066733] FFFF4AA0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.066742] FFFF4AC0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.066749] FFFF4AE0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.066757] FFFF4B00 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040483
[294019.066765] FFFF4B20 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.066773] FFFF4B40 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004048E
[294019.066781] FFFF4B60 : 00200011 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.066789] FFFF4B80 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.066797] FFFF4BA0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.066808] FFFF4BC0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040483 00240494
[294019.066815] FFFF4BE0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.066828] FFFF4C00 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.066838] FFFF4C20 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.066846] FFFF4C40 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.066854] FFFF4C60 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.066864] FFFF4C80 : 18000000 00000701 18000000 FFFFED00 18000000 00000701 18000000 00000701
[294019.066872] FFFF4CA0 : 18000000 E1D120B0 18000000 E3120001 18000000 00000001 18000000 5A900000
[294019.066880] FFFF4CC0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFE2C0
[294019.066894] User Command Buffer: 40000050, FFFF4D00 PID:822 Xorg
[294019.066903] FFFF4D00 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.066911] FFFF4D20 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.066919] FFFF4D40 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.066929] FFFF4D60 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.066937] FFFF4D80 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040468
[294019.066945] FFFF4DA0 : 00240473 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.066953] FFFF4DC0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040478
[294019.066961] FFFF4DE0 : 0020000B 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.066969] FFFF4E00 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.066978] FFFF4E20 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.066986] FFFF4E40 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040468 00240473
[294019.066994] FFFF4E60 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067002] FFFF4E80 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067010] FFFF4EA0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067018] FFFF4EC0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067026] FFFF4EE0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067035] FFFF4F00 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067043] FFFF4F20 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.067052] FFFF4F40 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFE310
[294019.067066] User Command Buffer: 40000050, FFFF4F80 PID:822 Xorg
[294019.067074] FFFF4F80 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.067083] FFFF4FA0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.067090] FFFF4FC0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.067098] FFFF4FE0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.067106] FFFF5000 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004044C
[294019.067116] FFFF5020 : 00240452 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.067124] FFFF5040 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040462
[294019.067133] FFFF5060 : 00200006 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.067143] FFFF5080 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.067151] FFFF50A0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.067160] FFFF50C0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004044C 00240452
[294019.067169] FFFF50E0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067177] FFFF5100 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067185] FFFF5120 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067194] FFFF5140 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067204] FFFF5160 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067212] FFFF5180 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067220] FFFF51A0 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.067230] FFFF51C0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFE360
[294019.067246] User Command Buffer: 40000050, FFFF5200 PID:822 Xorg
[294019.067254] FFFF5200 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.067262] FFFF5220 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.067270] FFFF5240 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.067278] FFFF5260 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.067286] FFFF5280 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040411
[294019.067296] FFFF52A0 : 00240431 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.067304] FFFF52C0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004042C
[294019.067312] FFFF52E0 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.067320] FFFF5300 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.067328] FFFF5320 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.067336] FFFF5340 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040411 00240431
[294019.067344] FFFF5360 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067353] FFFF5380 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067362] FFFF53A0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067370] FFFF53C0 : 18000000 00000701 18000000 00000701 18000000 00040498 18000000 00000000
[294019.067379] FFFF53E0 : 18000000 FFFFEC70 18000000 00000000 18000000 00000008 18000000 00000701
[294019.067393] FFFF5400 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067401] FFFF5420 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.067409] FFFF5440 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFE3B0
[294019.067420] Context Buffer: 00000000, 00000000 PID:18888 kworker/u8:3
[294019.067429] FFFFC000 : 08010E02 00000701 48000000 00000701 08010594 00000001 08015311 00000000
[294019.067437] FFFFC020 : 08010E02 00000701 48000000 00000701 10000000 00000000
[294019.067451] User Command Buffer: 40000050, FFFF5480 PID:822 Xorg
[294019.067460] FFFF5480 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.067469] FFFF54A0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.067479] FFFF54C0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.067487] FFFF54E0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.067495] FFFF5500 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040494
[294019.067503] FFFF5520 : 002404AE 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.067511] FFFF5540 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004049B
[294019.067519] FFFF5560 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.067528] FFFF5580 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.067536] FFFF55A0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.067547] FFFF55C0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040494 002404AE
[294019.067555] FFFF55E0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067565] FFFF5600 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067574] FFFF5620 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067582] FFFF5640 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067591] FFFF5660 : 18000000 FFFFECC0 18000000 00000701 18000000 00000701 18000000 1AFFFFE8
[294019.067601] FFFF5680 : 18000000 E1A02003 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067610] FFFF56A0 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.067618] FFFF56C0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFE400
[294019.067635] User Command Buffer: 40000050, FFFF5700 PID:822 Xorg
[294019.067644] FFFF5700 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.067653] FFFF5720 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.067663] FFFF5740 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.067671] FFFF5760 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.067683] FFFF5780 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040473
[294019.067693] FFFF57A0 : 00240487 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.067701] FFFF57C0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040480
[294019.067709] FFFF57E0 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.067718] FFFF5800 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.067726] FFFF5820 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.067734] FFFF5840 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040473 00240487
[294019.067742] FFFF5860 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067750] FFFF5880 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067759] FFFF58A0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067767] FFFF58C0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067775] FFFF58E0 : 18000000 FFFFED10 18000000 00000701 18000000 00000701 18000000 E1530004
[294019.067784] FFFF5900 : 18000000 0A000002 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067792] FFFF5920 : 18000000 00000500 18000000 00000008 18000000 FFFFE6D8 18000000 FFFFFDC7
[294019.067800] FFFF5940 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFE450
[294019.067818] User Command Buffer: 40000050, FFFF5980 PID:822 Xorg
[294019.067827] FFFF5980 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.067835] FFFF59A0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.067845] FFFF59C0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.067853] FFFF59E0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.067861] FFFF5A00 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040452
[294019.067870] FFFF5A20 : 0024045F 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.067878] FFFF5A40 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040466
[294019.067886] FFFF5A60 : 0020000D 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.067894] FFFF5A80 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.067902] FFFF5AA0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.067910] FFFF5AC0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040452 0024045F
[294019.067918] FFFF5AE0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.067926] FFFF5B00 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.067936] FFFF5B20 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.067945] FFFF5B40 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.067953] FFFF5B60 : 18000000 FFFFED60 18000000 00000701 18000000 00000701 18000000 E5933004
[294019.067962] FFFF5B80 : 18000000 BAFFFF82 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.067971] FFFF5BA0 : 18000000 00000500 18000000 00000008 18000000 FFFFF330 18000000 FFFFFDC7
[294019.067979] FFFF5BC0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFE4A0
[294019.067995] User Command Buffer: 40000050, FFFF5C00 PID:822 Xorg
[294019.068003] FFFF5C00 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.068011] FFFF5C20 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.068019] FFFF5C40 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.068032] FFFF5C60 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.068039] FFFF5C80 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040431
[294019.068048] FFFF5CA0 : 00240438 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.068056] FFFF5CC0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004044B
[294019.068064] FFFF5CE0 : 00200007 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.068071] FFFF5D00 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.068079] FFFF5D20 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.068089] FFFF5D40 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040431 00240438
[294019.068097] FFFF5D60 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.068105] FFFF5D80 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.068115] FFFF5DA0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068123] FFFF5DC0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.068132] FFFF5DE0 : 18000000 FFFFEDB0 18000000 00000701 18000000 00000701 18000000 E1A03007
[294019.068140] FFFF5E00 : 18000000 E3A01005 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.068150] FFFF5E20 : 18000000 00000500 18000000 00000008 18000000 FFFFFFE0 18000000 FFFFFDC7
[294019.068158] FFFF5E40 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFE4F0
[294019.068172] User Command Buffer: 40000050, FFFF5E80 PID:822 Xorg
[294019.068181] FFFF5E80 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.068190] FFFF5EA0 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.068197] FFFF5EC0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.068206] FFFF5EE0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.068214] FFFF5F00 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000403F0
[294019.068222] FFFF5F20 : 00240410 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.068230] FFFF5F40 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040411
[294019.068238] FFFF5F60 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.068247] FFFF5F80 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.068255] FFFF5FA0 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.068263] FFFF5FC0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 000403F0 00240410
[294019.068272] FFFF5FE0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.068280] FFFF6000 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.068288] FFFF6020 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068298] FFFF6040 : 18000000 00000701 18000000 00000701 18000000 E16F6F13 18000000 E1966FA0
[294019.068306] FFFF6060 : 18000000 FFFFEE10 18000000 DA000108 18000000 E50B8048 18000000 E5953008
[294019.068314] FFFF6080 : 18000000 E7933006 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.068325] FFFF60A0 : 18000000 00000500 18000000 00000008 18000000 FFFFEAC0 18000000 FFFFFDC7
[294019.068333] FFFF60C0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFE540
[294019.068347] User Command Buffer: 40000098, FFFF6100 PID:822 Xorg
[294019.068356] FFFF6100 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.068364] FFFF6120 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.068372] FFFF6140 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.068380] FFFF6160 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.068390] FFFF6180 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0000040D
[294019.068398] FFFF61A0 : 000404B9 0030CCCC 080204BA FFFFFFFF FFFFFFFF 002403EC 080104B5 00000000
[294019.068406] FFFF61C0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000003EC
[294019.068414] FFFF61E0 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.068422] FFFF6200 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.068430] FFFF6220 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.068438] FFFF6240 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0000040D 000404B9
[294019.068446] FFFF6260 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.068457] FFFF6280 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.068466] FFFF62A0 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068474] FFFF62C0 : 18000000 00000701 18000000 00000701 18000000 E1A052A5 18000000 1AFFFF33
[294019.068482] FFFF62E0 : 18000000 FFFFEE70 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.068490] FFFF6300 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.068498] FFFF6320 : 18000000 00000500 18000000 00000008 18000000 FFFFF7F8 18000000 FFFFFDC7
[294019.068506] FFFF6340 : 18000000 00000000 18000000 00000000 18000000 00000000 08010E00 00000001
[294019.068516] FFFF6360 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.068524] FFFF6380 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.068532] FFFF63A0 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.068542] FFFF63C0 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.068550] FFFF63E0 : 080104B1 00000000 080104B8 00000000 08020498 0024040D 002804B9 00000000
[294019.068558] FFFF6400 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.068566] FFFF6420 : 08010497 0030CCCC 080104B3 00000000 08020484 002403EC 000400AC 00000000
[294019.068578] FFFF6440 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.068586] FFFF6460 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.068594] FFFF6480 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.068603] FFFF64A0 : 0801048D A0002006 20000100 FFFFFF64 0024040D 002804B9 08010001 00000000
[294019.068611] FFFF64C0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.068619] FFFF64E0 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.068627] FFFF6500 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.068635] FFFF6520 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068643] FFFF6540 : 18000000 00000701 18000000 00000701 18000000 0A000066 18000000 E1130002
[294019.068651] FFFF6560 : 18000000 FFFFEEC0 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.068659] FFFF6580 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.068668] FFFF65A0 : 18000000 00000500 18000000 00000008 40000004 FFFFE5A0
[294019.068683] User Command Buffer: 4000004D, FFFF65D8 PID:822 Xorg
[294019.068691] FFFF65D8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.068700] FFFF65F8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.068708] FFFF6618 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.068718] FFFF6638 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.068726] FFFF6658 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040411
[294019.068734] FFFF6678 : 00240431 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.068742] FFFF6698 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000403F0
[294019.068750] FFFF66B8 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.068760] FFFF66D8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.068769] FFFF66F8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.068777] FFFF6718 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040411 00240431
[294019.068785] FFFF6738 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.068793] FFFF6758 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.068801] FFFF6778 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068809] FFFF6798 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.068817] FFFF67B8 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E1A08002
[294019.068825] FFFF67D8 : 18000000 E5133128 18000000 FFFFEF10 18000000 5A900000 18000000 00000500
[294019.068833] FFFF67F8 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.068842] FFFF6818 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFE5F0
[294019.068858] User Command Buffer: 4000004D, FFFF6858 PID:822 Xorg
[294019.068866] FFFF6858 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.068875] FFFF6878 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.068883] FFFF6898 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.068890] FFFF68B8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.068898] FFFF68D8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004044B
[294019.068908] FFFF68F8 : 00240452 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.068916] FFFF6918 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040431
[294019.068924] FFFF6938 : 00200007 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.068932] FFFF6958 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.068940] FFFF6978 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.068948] FFFF6998 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004044B 00240452
[294019.068956] FFFF69B8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.068964] FFFF69D8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.068974] FFFF69F8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.068982] FFFF6A18 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.068991] FFFF6A38 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 0A00001B
[294019.069000] FFFF6A58 : 18000000 E186600C 18000000 FFFFEF60 18000000 5A900000 18000000 00000500
[294019.069008] FFFF6A78 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.069016] FFFF6A98 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFE640
[294019.069036] User Command Buffer: 4000004D, FFFF6AD8 PID:822 Xorg
[294019.069046] FFFF6AD8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069055] FFFF6AF8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069063] FFFF6B18 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069071] FFFF6B38 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069079] FFFF6B58 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040466
[294019.069087] FFFF6B78 : 00240473 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.069097] FFFF6B98 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040452
[294019.069104] FFFF6BB8 : 0020000D 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.069112] FFFF6BD8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.069120] FFFF6BF8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.069130] FFFF6C18 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040466 00240473
[294019.069137] FFFF6C38 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.069146] FFFF6C58 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.069154] FFFF6C78 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.069162] FFFF6C98 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.069170] FFFF6CB8 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E3500000
[294019.069178] FFFF6CD8 : 18000000 E5943098 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.069188] FFFF6CF8 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.069196] FFFF6D18 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFE6A0
[294019.069213] User Command Buffer: 4000004D, FFFF6D58 PID:822 Xorg
[294019.069222] FFFF6D58 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069231] FFFF6D78 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069239] FFFF6D98 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069249] FFFF6DB8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069260] FFFF6DD8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040480
[294019.069268] FFFF6DF8 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.069276] FFFF6E18 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040473
[294019.069284] FFFF6E38 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.069292] FFFF6E58 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.069300] FFFF6E78 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.069310] FFFF6E98 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040480 00240494
[294019.069318] FFFF6EB8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.069326] FFFF6ED8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.069335] FFFF6EF8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.069343] FFFF6F18 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.069351] FFFF6F38 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 E24B702C
[294019.069360] FFFF6F58 : 18000000 E3A01001 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.069368] FFFF6F78 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.069379] FFFF6F98 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFE700
[294019.069393] User Command Buffer: 4000004D, FFFF6FD8 PID:822 Xorg
[294019.069402] FFFF6FD8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069411] FFFF6FF8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069419] FFFF7018 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069427] FFFF7038 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069435] FFFF7058 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049B
[294019.069443] FFFF7078 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.069451] FFFF7098 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040494
[294019.069459] FFFF70B8 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.069467] FFFF70D8 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.069475] FFFF70F8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.069483] FFFF7118 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049B 002404B5
[294019.069493] FFFF7138 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.069501] FFFF7158 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.069509] FFFF7178 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.069517] FFFF7198 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.069525] FFFF71B8 : 18000000 FFFFF000 18000000 00000701 18000000 00000701 18000000 E1A00004
[294019.069533] FFFF71D8 : 18000000 EBFFFFFE 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.069541] FFFF71F8 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.069550] FFFF7218 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFE750
[294019.069563] Context Buffer: 00000000, 00000000 PID:18879 kworker/u8:2
[294019.069572] FFFFC000 : 08010E02 00000701 48000000 00000701 08010594 00000001 08015311 00000000
[294019.069580] FFFFC020 : 08010E02 00000701 48000000 00000701 10000000 00000000
[294019.069591] User Command Buffer: 4000004D, FFFF7258 PID:822 Xorg
[294019.069600] FFFF7258 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069610] FFFF7278 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069618] FFFF7298 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069626] FFFF72B8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069634] FFFF72D8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049A
[294019.069642] FFFF72F8 : 002404BA 00000320 080204BA FFFFFFFF FFFFFFFF FFFFFF64 080104B5 00000000
[294019.069650] FFFF7318 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040495
[294019.069658] FFFF7338 : 00200020 00240452 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.069666] FFFF7358 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.069676] FFFF7378 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.069684] FFFF7398 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004049A 002404BA
[294019.069695] FFFF73B8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.069703] FFFF73D8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.069711] FFFF73F8 : 48000000 00000701 18000000 000404B9 18000000 00000000 18000000 00000000
[294019.069719] FFFF7418 : 18000000 00000000 18000000 00000008 18000000 00000701 18000000 00000701
[294019.069727] FFFF7438 : 18000000 FFFFF050 18000000 00000701 18000000 00000701 18000000 135E0001
[294019.069737] FFFF7458 : 18000000 E1A03002 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.069745] FFFF7478 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.069753] FFFF7498 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFE7A0
[294019.069768] User Command Buffer: 4000004D, FFFF74D8 PID:822 Xorg
[294019.069776] FFFF74D8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069785] FFFF74F8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069793] FFFF7518 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069801] FFFF7538 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069808] FFFF7558 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004047F
[294019.069816] FFFF7578 : 0024049F 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.069824] FFFF7598 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040474
[294019.069832] FFFF75B8 : 00200020 00240473 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.069840] FFFF75D8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.069849] FFFF75F8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.069859] FFFF7618 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004047F 0024049F
[294019.069869] FFFF7638 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.069877] FFFF7658 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.069885] FFFF7678 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.069893] FFFF7698 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.069901] FFFF76B8 : 18000000 FFFFF0A0 18000000 00000701 18000000 00000701 18000000 E5D32000
[294019.069910] FFFF76D8 : 18000000 1AFFFF9D 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.069920] FFFF76F8 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.069928] FFFF7718 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFE7F0
[294019.069941] User Command Buffer: 4000004D, FFFF7758 PID:822 Xorg
[294019.069951] FFFF7758 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.069960] FFFF7778 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.069968] FFFF7798 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.069976] FFFF77B8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.069984] FFFF77D8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040463
[294019.069992] FFFF77F8 : 00240483 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.070001] FFFF7818 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040453
[294019.070008] FFFF7838 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.070016] FFFF7858 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.070025] FFFF7878 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.070033] FFFF7898 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040463 00240483
[294019.070042] FFFF78B8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.070050] FFFF78D8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.070059] FFFF78F8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.070068] FFFF7918 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.070076] FFFF7938 : 18000000 FFFFF100 18000000 00000701 18000000 00000701 18000000 E59B9004
[294019.070084] FFFF7958 : 18000000 E1A0A004 18000000 FFFFEA78 18000000 5A900000 18000000 00000500
[294019.070092] FFFF7978 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.070100] FFFF7998 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFE840
[294019.070114] User Command Buffer: 4000004D, FFFF79D8 PID:822 Xorg
[294019.070122] FFFF79D8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.070130] FFFF79F8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.070138] FFFF7A18 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.070146] FFFF7A38 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.070154] FFFF7A58 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040448
[294019.070164] FFFF7A78 : 00240468 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.070172] FFFF7A98 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040432
[294019.070180] FFFF7AB8 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.070190] FFFF7AD8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.070198] FFFF7AF8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.070206] FFFF7B18 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040448 00240468
[294019.070214] FFFF7B38 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.070222] FFFF7B58 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.070230] FFFF7B78 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.070238] FFFF7B98 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.070246] FFFF7BB8 : 18000000 FFFFF160 18000000 00000701 18000000 00000701 18000000 E3A01099
[294019.070259] FFFF7BD8 : 18000000 E3A02008 18000000 FFFFF6B0 18000000 5A900000 18000000 00000500
[294019.070267] FFFF7BF8 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.070276] FFFF7C18 : 18000000 00000500 18000000 00000500 18000000 00000008 40000006 FFFFE890
[294019.070289] User Command Buffer: 4000004D, FFFF7C58 PID:822 Xorg
[294019.070297] FFFF7C58 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.070306] FFFF7C78 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.070314] FFFF7C98 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.070321] FFFF7CB8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.070329] FFFF7CD8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004042C
[294019.070337] FFFF7CF8 : 0024044C 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.070347] FFFF7D18 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040411
[294019.070356] FFFF7D38 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.070363] FFFF7D58 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.070371] FFFF7D78 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.070380] FFFF7D98 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004042C 0024044C
[294019.070390] FFFF7DB8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.070398] FFFF7DD8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.070408] FFFF7DF8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.070417] FFFF7E18 : 18000000 00000701 18000000 00000701 18000000 1A0000B7 18000000 E5978098
[294019.070425] FFFF7E38 : 18000000 FFFFF1B0 18000000 E1A02004 18000000 E1A00007 18000000 E3580000
[294019.070434] FFFF7E58 : 18000000 11A00FA0 18000000 FFFFE3C8 18000000 5A900000 18000000 00000500
[294019.070442] FFFF7E78 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.070450] FFFF7E98 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFE8F0
[294019.070466] User Command Buffer: 400000E5, FFFF7ED8 PID:822 Xorg
[294019.070474] FFFF7ED8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.070482] FFFF7EF8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.070490] FFFF7F18 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.070500] FFFF7F38 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.070508] FFFF7F58 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000003EC
[294019.070516] FFFF7F78 : 00040498 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.070528] FFFF7F98 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0000040D
[294019.070536] FFFF7FB8 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.070544] FFFF7FD8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.070552] FFFF7FF8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.070561] FFFF8018 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 000003EC 00040498
[294019.070569] FFFF8038 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.070577] FFFF8058 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.070586] FFFF8078 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.070595] FFFF8098 : 18000000 00000701 18000000 00000701 18000000 EAFFFF0B 18000000 E3A01010
[294019.070603] FFFF80B8 : 18000000 FFFFF200 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.070611] FFFF80D8 : 18000000 00000008 18000000 FFFFEE50 18000000 5A900000 18000000 00000500
[294019.070619] FFFF80F8 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.070627] FFFF8118 : 18000000 00000500 18000000 00000500 18000000 00000008 08010E00 00000001
[294019.070635] FFFF8138 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.070643] FFFF8158 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.070652] FFFF8178 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.070660] FFFF8198 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.070668] FFFF81B8 : 080104B1 00000000 080104B8 00000000 08020498 000403EC 0024040B 0030CCCC
[294019.070678] FFFF81D8 : 080204BA FFFFFFFF FFFFFFFF 0024040D 080104B5 00000000 080104B6 FFFFF6FF
[294019.070686] FFFF81F8 : 08010497 0030CCCC 080104B3 00000000 08020484 0004040D 0020001F 00000000
[294019.070694] FFFF8218 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.070702] FFFF8238 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.070711] FFFF8258 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.070719] FFFF8278 : 0801048D A0002006 20000100 00000008 000403EC 0024040B 08010001 00000000
[294019.070726] FFFF8298 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.070734] FFFF82B8 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.070744] FFFF82D8 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.070752] FFFF82F8 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 FFFFF380
[294019.070762] FFFF8318 : 18000000 00000701 18000000 00000701 18000000 EAFFFFDA 18000000 E3403000
[294019.070775] FFFF8338 : 18000000 FFFFF250 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.070783] FFFF8358 : 18000000 00000008 18000000 FFFFFB78 18000000 5A900000 18000000 00000500
[294019.070791] FFFF8378 : 18000000 00000500 18000000 00000008 08010E00 00000001 0803048A 5A900000
[294019.070799] FFFF8398 : 00001400 00000500 080104E8 00000500 08010E03 00000008 080104AD 00000320
[294019.070807] FFFF83B8 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 08014A98 00000000
[294019.070815] FFFF83D8 : 08014A99 00000000 08014A9A 00000000 08014A9B 00000000 08014A9C 00000000
[294019.070823] FFFF83F8 : 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000 080104B1 00000000
[294019.070831] FFFF8418 : 080104B8 00000000 08020498 002403EC 00280498 00000000 080204BA FFFFFFFF
[294019.070839] FFFF8438 : FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
[294019.070848] FFFF8458 : 080104B3 00000000 08020484 0024040D 000400AC 00000000 08014A60 00000500
[294019.070855] FFFF8478 : 080104C0 00000000 08040480 5A900000 00001400 00000500 06000006 00000000
[294019.070863] FFFF8498 : 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8 080104B6 FFFFFF64
[294019.070872] FFFF84B8 : 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF 0801048D A0002006
[294019.070882] FFFF84D8 : 20000100 FFFFFF64 002403EC 00280498 08010001 00000000 08010001 00000000
[294019.070892] FFFF84F8 : 08010001 00000000 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.070900] FFFF8518 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 00000701
[294019.070908] FFFF8538 : 18000000 00000701 18000000 00000008 18000000 00000701 18000000 00000701
[294019.070917] FFFF8558 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.070927] FFFF8578 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 FFFFF3E0
[294019.070935] FFFF8598 : 18000000 00000701 18000000 00000701 18000000 E593C010 18000000 E50BC028
[294019.070944] FFFF85B8 : 18000000 FFFFF2A0 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.070950] FFFF85D8 : 18000000 00000008 40000008 FFFFE940
[294019.070964] User Command Buffer: 4000004F, FFFF8608 PID:822 Xorg
[294019.070972] FFFF8608 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.070983] FFFF8628 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.070992] FFFF8648 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071002] FFFF8668 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071010] FFFF8688 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049F
[294019.071019] FFFF86A8 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071027] FFFF86C8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000404A4
[294019.071035] FFFF86E8 : 00200016 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071044] FFFF8708 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.071053] FFFF8728 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.071061] FFFF8748 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049F 002404B5
[294019.071069] FFFF8768 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.071077] FFFF8788 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.071085] FFFF87A8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.071093] FFFF87C8 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071101] FFFF87E8 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071110] FFFF8808 : 18000000 00000701 18000000 FFFFF440 18000000 00000701 18000000 00000701
[294019.071118] FFFF8828 : 18000000 EBFFFFFE 18000000 0A000018 18000000 FFFFF2F0 18000000 5A900000
[294019.071127] FFFF8848 : 18000000 00000500 18000000 00000500 18000000 00000008 40000006 FFFFE990
[294019.071142] User Command Buffer: 4000004F, FFFF8888 PID:822 Xorg
[294019.071151] FFFF8888 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.071159] FFFF88A8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.071167] FFFF88C8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071175] FFFF88E8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071182] FFFF8908 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040483
[294019.071190] FFFF8928 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071198] FFFF8948 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004048E
[294019.071207] FFFF8968 : 00200011 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071215] FFFF8988 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.071227] FFFF89A8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.071236] FFFF89C8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040483 00240494
[294019.071244] FFFF89E8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.071252] FFFF8A08 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.071260] FFFF8A28 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.071268] FFFF8A48 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071276] FFFF8A68 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071284] FFFF8A88 : 18000000 00000701 18000000 FFFFF4A0 18000000 00000701 18000000 00000701
[294019.071294] FFFF8AA8 : 18000000 E3E08059 18000000 E24BD028 18000000 00000001 18000000 5A900000
[294019.071302] FFFF8AC8 : 18000000 00000500 18000000 00000500 18000000 00000008 40000004 FFFFE9E0
[294019.071315] User Command Buffer: 4000004F, FFFF8B08 PID:822 Xorg
[294019.071325] FFFF8B08 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.071333] FFFF8B28 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.071341] FFFF8B48 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071350] FFFF8B68 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071357] FFFF8B88 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040468
[294019.071369] FFFF8BA8 : 00240473 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071377] FFFF8BC8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040478
[294019.071385] FFFF8BE8 : 0020000B 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071393] FFFF8C08 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.071402] FFFF8C28 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.071411] FFFF8C48 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040468 00240473
[294019.071419] FFFF8C68 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.071427] FFFF8C88 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.071435] FFFF8CA8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.071443] FFFF8CC8 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071451] FFFF8CE8 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071459] FFFF8D08 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.071468] FFFF8D28 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.071476] FFFF8D48 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFEA40
[294019.071491] User Command Buffer: 4000004F, FFFF8D88 PID:822 Xorg
[294019.071499] FFFF8D88 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.071508] FFFF8DA8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.071515] FFFF8DC8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071523] FFFF8DE8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071532] FFFF8E08 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004044C
[294019.071540] FFFF8E28 : 00240452 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071549] FFFF8E48 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040462
[294019.071557] FFFF8E68 : 00200006 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071565] FFFF8E88 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.071573] FFFF8EA8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.071581] FFFF8EC8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004044C 00240452
[294019.071589] FFFF8EE8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.071598] FFFF8F08 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.071607] FFFF8F28 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.071615] FFFF8F48 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071622] FFFF8F68 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 00000701
[294019.071633] FFFF8F88 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.071641] FFFF8FA8 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.071649] FFFF8FC8 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFEA90
[294019.071663] User Command Buffer: 4000004F, FFFF9008 PID:822 Xorg
[294019.071671] FFFF9008 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.071679] FFFF9028 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.071687] FFFF9048 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071695] FFFF9068 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071703] FFFF9088 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040411
[294019.071711] FFFF90A8 : 00240431 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071721] FFFF90C8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004042C
[294019.071729] FFFF90E8 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071737] FFFF9108 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.071746] FFFF9128 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.071755] FFFF9148 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040411 00240431
[294019.071763] FFFF9168 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.071771] FFFF9188 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.071779] FFFF91A8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.071787] FFFF91C8 : 18000000 00000701 18000000 00000701 18000000 00040498 18000000 00000000
[294019.071795] FFFF91E8 : 18000000 FFFFF390 18000000 00000000 18000000 00000008 18000000 00000701
[294019.071803] FFFF9208 : 18000000 00000701 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.071812] FFFF9228 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.071820] FFFF9248 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFEAE0
[294019.071830] Context Buffer: 00000000, 00000000 PID:18888 kworker/u8:3
[294019.071839] FFFFC000 : 08010E02 00000701 48000000 00000701 08010594 00000001 08015311 00000000
[294019.071846] FFFFC020 : 08010E02 00000701 48000000 00000701 10000000 00000000
[294019.071908] User Command Buffer: 4000004F, FFFF9288 PID:822 Xorg
[294019.071918] FFFF9288 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.071927] FFFF92A8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.071935] FFFF92C8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.071943] FFFF92E8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.071951] FFFF9308 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040494
[294019.071960] FFFF9328 : 002404AE 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.071968] FFFF9348 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004049B
[294019.071976] FFFF9368 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.071985] FFFF9388 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.071995] FFFF93A8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072004] FFFF93C8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040494 002404AE
[294019.072011] FFFF93E8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072020] FFFF9408 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072028] FFFF9428 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072036] FFFF9448 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.072044] FFFF9468 : 18000000 FFFFF3E0 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.072053] FFFF9488 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072061] FFFF94A8 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.072069] FFFF94C8 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFEB30
[294019.072088] User Command Buffer: 4000004F, FFFF9508 PID:822 Xorg
[294019.072097] FFFF9508 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.072105] FFFF9528 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.072113] FFFF9548 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.072121] FFFF9568 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.072129] FFFF9588 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040473
[294019.072137] FFFF95A8 : 00240487 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.072145] FFFF95C8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040480
[294019.072153] FFFF95E8 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.072161] FFFF9608 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.072170] FFFF9628 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072179] FFFF9648 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040473 00240487
[294019.072186] FFFF9668 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072194] FFFF9688 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072204] FFFF96A8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072212] FFFF96C8 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.072220] FFFF96E8 : 18000000 FFFFF430 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.072228] FFFF9708 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072236] FFFF9728 : 18000000 00000500 18000000 00000008 18000000 FFFFEDF8 18000000 FFFFFDC7
[294019.072244] FFFF9748 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFEB80
[294019.072265] User Command Buffer: 4000004F, FFFF9788 PID:822 Xorg
[294019.072274] FFFF9788 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.072283] FFFF97A8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.072291] FFFF97C8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.072300] FFFF97E8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.072308] FFFF9808 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040452
[294019.072316] FFFF9828 : 0024045F 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.072326] FFFF9848 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040466
[294019.072335] FFFF9868 : 0020000D 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.072343] FFFF9888 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.072351] FFFF98A8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072362] FFFF98C8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040452 0024045F
[294019.072370] FFFF98E8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072378] FFFF9908 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072386] FFFF9928 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072395] FFFF9948 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.072404] FFFF9968 : 18000000 FFFFF480 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.072412] FFFF9988 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072420] FFFF99A8 : 18000000 00000500 18000000 00000008 18000000 FFFFFA60 18000000 FFFFFDC7
[294019.072428] FFFF99C8 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFEBD0
[294019.072444] User Command Buffer: 4000004F, FFFF9A08 PID:822 Xorg
[294019.072454] FFFF9A08 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.072462] FFFF9A28 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.072470] FFFF9A48 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.072477] FFFF9A68 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.072486] FFFF9A88 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040431
[294019.072494] FFFF9AA8 : 00240438 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.072502] FFFF9AC8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004044B
[294019.072510] FFFF9AE8 : 00200007 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.072518] FFFF9B08 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.072526] FFFF9B28 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072535] FFFF9B48 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040431 00240438
[294019.072545] FFFF9B68 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072553] FFFF9B88 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072563] FFFF9BA8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072571] FFFF9BC8 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.072580] FFFF9BE8 : 18000000 FFFFF4D0 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.072588] FFFF9C08 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072596] FFFF9C28 : 18000000 00000500 18000000 00000008 18000000 FFFFE748 18000000 FFFFFDC7
[294019.072606] FFFF9C48 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFEC20
[294019.072620] User Command Buffer: 4000004F, FFFF9C88 PID:822 Xorg
[294019.072631] FFFF9C88 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.072639] FFFF9CA8 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.072647] FFFF9CC8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.072655] FFFF9CE8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.072663] FFFF9D08 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000403F0
[294019.072671] FFFF9D28 : 00240410 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.072679] FFFF9D48 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040411
[294019.072687] FFFF9D68 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.072697] FFFF9D88 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.072705] FFFF9DA8 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072713] FFFF9DC8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 000403F0 00240410
[294019.072722] FFFF9DE8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072730] FFFF9E08 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072739] FFFF9E28 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072747] FFFF9E48 : 18000000 00000701 18000000 00000701 18000000 8B8B8B8B 18000000 8B8B8B8B
[294019.072755] FFFF9E68 : 18000000 FFFFF520 18000000 8B8B8B8B 18000000 8B8B8B8B 18000000 8B8B8B8B
[294019.072764] FFFF9E88 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072772] FFFF9EA8 : 18000000 00000500 18000000 00000008 18000000 FFFFF220 18000000 FFFFFDC7
[294019.072780] FFFF9EC8 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFEC70
[294019.072794] User Command Buffer: 40000097, FFFF9F08 PID:822 Xorg
[294019.072802] FFFF9F08 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.072811] FFFF9F28 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.072819] FFFF9F48 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.072830] FFFF9F68 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.072838] FFFF9F88 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0000040D
[294019.072846] FFFF9FA8 : 000404B9 0030CCCC 080204BA FFFFFFFF FFFFFFFF 002403EC 080104B5 00000000
[294019.072854] FFFF9FC8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000003EC
[294019.072862] FFFF9FE8 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.072871] FFFFA008 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.072880] FFFFA028 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.072889] FFFFA048 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0000040D 000404B9
[294019.072896] FFFFA068 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.072906] FFFFA088 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.072914] FFFFA0A8 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.072923] FFFFA0C8 : 18000000 00000701 18000000 00000701 18000000 8B8B8B8B 18000000 8B8B8B8B
[294019.072931] FFFFA0E8 : 18000000 FFFFF570 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.072941] FFFFA108 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.072950] FFFFA128 : 18000000 00000500 18000000 00000008 18000000 FFFFFEE8 18000000 FFFFFDC7
[294019.072957] FFFFA148 : 18000000 00000000 18000000 00000000 18000000 00000000 08010E00 00000001
[294019.072965] FFFFA168 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.072973] FFFFA188 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.072981] FFFFA1A8 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.072992] FFFFA1C8 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.073003] FFFFA1E8 : 080104B1 00000000 080104B8 00000000 08020498 0024040D 002804B9 00000000
[294019.073011] FFFFA208 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.073019] FFFFA228 : 08010497 0030CCCC 080104B3 00000000 08020484 002403EC 000400AC 00000000
[294019.073027] FFFFA248 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.073035] FFFFA268 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.073043] FFFFA288 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.073052] FFFFA2A8 : 0801048D A0002006 20000100 FFFFFF64 0024040D 002804B9 08010001 00000000
[294019.073060] FFFFA2C8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.073068] FFFFA2E8 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.073076] FFFFA308 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.073084] FFFFA328 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073094] FFFFA348 : 18000000 00000701 18000000 00000701 18000000 8B8B8B8B 18000000 8B8B8B8B
[294019.073102] FFFFA368 : 18000000 FFFFF5C0 18000000 5A900000 18000000 00000500 18000000 00000500
[294019.073110] FFFFA388 : 18000000 00000008 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.073118] FFFFA3A8 : 18000000 00000500 18000000 00000008 40000008 FFFFECC0
[294019.073132] User Command Buffer: 4000004C, FFFFA3E0 PID:822 Xorg
[294019.073141] FFFFA3E0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.073149] FFFFA400 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.073157] FFFFA420 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.073165] FFFFA440 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.073173] FFFFA460 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040411
[294019.073181] FFFFA480 : 00240431 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.073189] FFFFA4A0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000403F0
[294019.073197] FFFFA4C0 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.073205] FFFFA4E0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.073213] FFFFA500 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.073221] FFFFA520 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040411 00240431
[294019.073229] FFFFA540 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.073237] FFFFA560 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.073247] FFFFA580 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073258] FFFFA5A0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.073266] FFFFA5C0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.073275] FFFFA5E0 : 18000000 8B8B8B8B 18000000 FFFFF610 18000000 5A900000 18000000 00000500
[294019.073283] FFFFA600 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.073291] FFFFA620 : 18000000 00000500 18000000 00000500 18000000 00000008 40000006 FFFFED10
[294019.073305] User Command Buffer: 4000004C, FFFFA660 PID:822 Xorg
[294019.073313] FFFFA660 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.073321] FFFFA680 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.073329] FFFFA6A0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.073338] FFFFA6C0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.073346] FFFFA6E0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004044B
[294019.073354] FFFFA700 : 00240452 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.073362] FFFFA720 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040431
[294019.073370] FFFFA740 : 00200007 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.073378] FFFFA760 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.073386] FFFFA780 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.073395] FFFFA7A0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004044B 00240452
[294019.073402] FFFFA7C0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.073410] FFFFA7E0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.073418] FFFFA800 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073426] FFFFA820 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.073434] FFFFA840 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.073443] FFFFA860 : 18000000 8B8B8B8B 18000000 FFFFF660 18000000 5A900000 18000000 00000500
[294019.073451] FFFFA880 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.073460] FFFFA8A0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000004 FFFFED60
[294019.073474] User Command Buffer: 4000004C, FFFFA8E0 PID:822 Xorg
[294019.073483] FFFFA8E0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.073491] FFFFA900 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.073499] FFFFA920 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.073506] FFFFA940 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.073516] FFFFA960 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040466
[294019.073524] FFFFA980 : 00240473 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.073532] FFFFA9A0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040452
[294019.073540] FFFFA9C0 : 0020000D 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.073548] FFFFA9E0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.073556] FFFFAA00 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.073565] FFFFAA20 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040466 00240473
[294019.073572] FFFFAA40 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.073582] FFFFAA60 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.073590] FFFFAA80 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073598] FFFFAAA0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.073608] FFFFAAC0 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 8B8B8B8B
[294019.073616] FFFFAAE0 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.073625] FFFFAB00 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.073632] FFFFAB20 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFEDB0
[294019.073646] User Command Buffer: 4000004C, FFFFAB60 PID:822 Xorg
[294019.073655] FFFFAB60 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.073663] FFFFAB80 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.073673] FFFFABA0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.073681] FFFFABC0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.073689] FFFFABE0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040480
[294019.073699] FFFFAC00 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.073707] FFFFAC20 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040473
[294019.073716] FFFFAC40 : 00200014 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.073723] FFFFAC60 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.073731] FFFFAC80 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.073740] FFFFACA0 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040480 00240494
[294019.073747] FFFFACC0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.073755] FFFFACE0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.073765] FFFFAD00 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073774] FFFFAD20 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.073782] FFFFAD40 : 18000000 00000008 18000000 00000701 18000000 00000701 18000000 DFDFDFDF
[294019.073792] FFFFAD60 : 18000000 8B8B8B8B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.073800] FFFFAD80 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.073808] FFFFADA0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000008 FFFFEE00
[294019.073822] User Command Buffer: 4000004C, FFFFADE0 PID:822 Xorg
[294019.073830] FFFFADE0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.073838] FFFFAE00 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.073846] FFFFAE20 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.073856] FFFFAE40 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.073864] FFFFAE60 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049B
[294019.073872] FFFFAE80 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.073882] FFFFAEA0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040494
[294019.073890] FFFFAEC0 : 0020001A 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.073899] FFFFAEE0 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.073907] FFFFAF00 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.073915] FFFFAF20 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049B 002404B5
[294019.073923] FFFFAF40 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.073931] FFFFAF60 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.073939] FFFFAF80 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.073948] FFFFAFA0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.073956] FFFFAFC0 : 18000000 FFFFF700 18000000 00000701 18000000 00000701 18000000 7B7B7B7B
[294019.073965] FFFFAFE0 : 18000000 7B7B7B7B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.073974] FFFFB000 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.073982] FFFFB020 : 18000000 00000000 18000000 00000000 18000000 00000000 40000006 FFFFEE50
[294019.073992] Context Buffer: 00000000, 00000000 PID:18888 kworker/u8:3
[294019.074001] FFFFC000 : 08010E02 00000701 48000000 00000701 08010594 00000001 08015311 00000000
[294019.074009] FFFFC020 : 08010E02 00000701 48000000 00000701 10000000 00000000
[294019.074020] User Command Buffer: 4000004C, FFFFB060 PID:822 Xorg
[294019.074028] FFFFB060 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074037] FFFFB080 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074044] FFFFB0A0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074056] FFFFB0C0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074065] FFFFB0E0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049A
[294019.074073] FFFFB100 : 002404BA 00000320 080204BA FFFFFFFF FFFFFFFF FFFFFF64 080104B5 00000000
[294019.074081] FFFFB120 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040495
[294019.074089] FFFFB140 : 00200020 00240452 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074097] FFFFB160 : 00001400 00000500 06000006 00000701 08010E03 00000008 080104AE 00000320
[294019.074106] FFFFB180 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074114] FFFFB1A0 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004049A 002404BA
[294019.074122] FFFFB1C0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074131] FFFFB1E0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.074140] FFFFB200 : 48000000 00000701 18000000 000404B9 18000000 00000000 18000000 00000000
[294019.074147] FFFFB220 : 18000000 00000000 18000000 00000008 18000000 00000701 18000000 00000701
[294019.074156] FFFFB240 : 18000000 FFFFF750 18000000 00000701 18000000 00000701 18000000 7B7B7B7B
[294019.074164] FFFFB260 : 18000000 7B7B7B7B 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.074172] FFFFB280 : 18000000 00000500 18000000 00000008 18000000 00000320 18000000 FFFFFDC7
[294019.074180] FFFFB2A0 : 18000000 00000000 18000000 00000000 18000000 00000000 40000004 FFFFEEA0
[294019.074196] User Command Buffer: 4000004C, FFFFB2E0 PID:822 Xorg
[294019.074205] FFFFB2E0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074213] FFFFB300 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074223] FFFFB320 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074230] FFFFB340 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074238] FFFFB360 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004047F
[294019.074248] FFFFB380 : 0024049F 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.074257] FFFFB3A0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040474
[294019.074264] FFFFB3C0 : 00200020 00240473 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074272] FFFFB3E0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.074280] FFFFB400 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074289] FFFFB420 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004047F 0024049F
[294019.074297] FFFFB440 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074305] FFFFB460 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.074315] FFFFB480 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.074323] FFFFB4A0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.074332] FFFFB4C0 : 18000000 FFFFF7A0 18000000 00000701 18000000 00000701 18000000 000000DA
[294019.074340] FFFFB4E0 : 18000000 000000D9 18000000 00000001 18000000 5A900000 18000000 00000500
[294019.074348] FFFFB500 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.074357] FFFFB520 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFEEF0
[294019.074371] User Command Buffer: 4000004C, FFFFB560 PID:822 Xorg
[294019.074379] FFFFB560 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074388] FFFFB580 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074395] FFFFB5A0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074405] FFFFB5C0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074413] FFFFB5E0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040463
[294019.074421] FFFFB600 : 00240483 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.074429] FFFFB620 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040453
[294019.074437] FFFFB640 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074445] FFFFB660 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.074453] FFFFB680 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074462] FFFFB6A0 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040463 00240483
[294019.074470] FFFFB6C0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074478] FFFFB6E0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.074486] FFFFB700 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.074497] FFFFB720 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.074505] FFFFB740 : 18000000 FFFFF7F0 18000000 00000701 18000000 00000701 18000000 00000020
[294019.074513] FFFFB760 : 18000000 00000020 18000000 FFFFF198 18000000 5A900000 18000000 00000500
[294019.074523] FFFFB780 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.074531] FFFFB7A0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000008 FFFFEF40
[294019.074545] User Command Buffer: 4000004C, FFFFB7E0 PID:822 Xorg
[294019.074553] FFFFB7E0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074561] FFFFB800 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074570] FFFFB820 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074577] FFFFB840 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074585] FFFFB860 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040448
[294019.074594] FFFFB880 : 00240468 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.074602] FFFFB8A0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040432
[294019.074610] FFFFB8C0 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074620] FFFFB8E0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.074628] FFFFB900 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074636] FFFFB920 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 00040448 00240468
[294019.074644] FFFFB940 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074653] FFFFB960 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.074661] FFFFB980 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.074669] FFFFB9A0 : 18000000 00000701 18000000 00000701 18000000 00000701 18000000 00000701
[294019.074677] FFFFB9C0 : 18000000 FFFFF840 18000000 00000701 18000000 00000701 18000000 00000000
[294019.074685] FFFFB9E0 : 18000000 00000000 18000000 FFFFFDF0 18000000 5A900000 18000000 00000500
[294019.074693] FFFFBA00 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.074702] FFFFBA20 : 18000000 00000500 18000000 00000500 18000000 00000008 40000004 FFFFEFA0
[294019.074716] User Command Buffer: 4000004C, FFFFBA60 PID:822 Xorg
[294019.074725] FFFFBA60 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074733] FFFFBA80 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074742] FFFFBAA0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074750] FFFFBAC0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074757] FFFFBAE0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004042C
[294019.074767] FFFFBB00 : 0024044C 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.074775] FFFFBB20 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 00040411
[294019.074783] FFFFBB40 : 00200020 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074795] FFFFBB60 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.074803] FFFFBB80 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074811] FFFFBBA0 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 0004042C 0024044C
[294019.074819] FFFFBBC0 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074827] FFFFBBE0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.074835] FFFFBC00 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.074843] FFFFBC20 : 18000000 00000701 18000000 00000701 18000000 00000000 18000000 00000000
[294019.074851] FFFFBC40 : 18000000 FFFFF890 18000000 00000000 18000000 00000000 18000000 00000000
[294019.074859] FFFFBC60 : 18000000 00000000 18000000 FFFFEAC8 18000000 5A900000 18000000 00000500
[294019.074867] FFFFBC80 : 18000000 00000500 18000000 00000008 18000000 00000001 18000000 5A900000
[294019.074875] FFFFBCA0 : 18000000 00000500 18000000 00000500 18000000 00000008 40000002 FFFFEFF0
[294019.074889] User Command Buffer: 4000004C, FFFFBCE0 PID:822 Xorg
[294019.074898] FFFFBCE0 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.074906] FFFFBD00 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.074914] FFFFBD20 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.074922] FFFFBD40 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.074933] FFFFBD60 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000003EC
[294019.074941] FFFFBD80 : 00040498 0030CCCC 080204BA FFFFFFFF FFFFFFFF 0004040D 080104B5 00000000
[294019.074950] FFFFBDA0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0000040D
[294019.074958] FFFFBDC0 : 000400AC 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.074966] FFFFBDE0 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.074974] FFFFBE00 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.074982] FFFFBE20 : 080104AF FFF44FFF 0801048D A0002006 20000100 00000008 000003EC 00040498
[294019.074990] FFFFBE40 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.074998] FFFFBE60 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.075007] FFFFBE80 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.075016] FFFFBEA0 : 18000000 00000701 18000000 00000701 18000000 00000000 18000000 00000000
[294019.075025] FFFFBEC0 : 18000000 FFFFF8E0 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075033] FFFFBEE0 : 18000000 00000000 18000000 FFFFF5B0 18000000 00000000 18000000 00000000
[294019.075042] FFFFBF00 : 18000000 00000000 18000000 00000000 18000000 FFFFE2C0 18000000 00000000
[294019.075051] FFFFBF20 : 18000000 00000000 18000000 00000000 18000000 00000000 40000005 FFFFF058
[294019.075069] User Command Buffer: 4000009C, FFFBC020 PID:822 Xorg
[294019.075078] FFFBC020 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.075086] FFFBC040 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.075095] FFFBC060 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.075103] FFFBC080 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.075111] FFFBC0A0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 000403EC
[294019.075119] FFFBC0C0 : 0024040B FFFFFF82 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.075127] FFFBC0E0 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004040D
[294019.075136] FFFBC100 : 0020001F FFFFDF41 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.075144] FFFBC120 : 00001400 00000500 06000006 FFFFFFF0 08010E03 00000008 080104AE 00000320
[294019.075152] FFFBC140 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.075160] FFFBC160 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFD619 000403EC 0024040B
[294019.075169] FFFBC180 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.075177] FFFBC1A0 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.075187] FFFBC1C0 : 48000000 00000701 18000000 00000000 18000000 00000000 18000000 FFFFE3A0
[294019.075195] FFFBC1E0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075203] FFFBC200 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075210] FFFBC220 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075218] FFFBC240 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075226] FFFBC260 : 18000000 00000000 18000000 00000000 18000000 00000000 08010E00 00000001
[294019.075234] FFFBC280 : 0803048A 5A900000 00001400 00000500 080104E8 00000500 08010E03 00000008
[294019.075242] FFFBC2A0 : 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
[294019.075250] FFFBC2C0 : 08014A98 00000000 08014A99 00000000 08014A9A 00000000 08014A9B 00000000
[294019.075260] FFFBC2E0 : 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000 08014A9F 00000000
[294019.075268] FFFBC300 : 080104B1 00000000 080104B8 00000000 08020498 002403EC 00280498 00000000
[294019.075276] FFFBC320 : 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF
[294019.075286] FFFBC340 : 08010497 0030CCCC 080104B3 00000000 08020484 0024040D 000400AC 00000000
[294019.075294] FFFBC360 : 08014A60 00000500 080104C0 00000000 08040480 5A900000 00001400 00000500
[294019.075302] FFFBC380 : 06000006 00000000 08010E03 00000008 080104AE 00000320 080104AF FFFFFEF8
[294019.075310] FFFBC3A0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
[294019.075318] FFFBC3C0 : 0801048D A0002006 20000100 FFFFFF64 002403EC 00280498 08010001 00000000
[294019.075326] FFFBC3E0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
[294019.075334] FFFBC400 : 48000000 00000701 08010E03 00000008 08010E02 00000701 48000000 00000701
[294019.075347] FFFBC420 : 18000000 00000701 18000000 00000701 18000000 00000008 18000000 00000701
[294019.075355] FFFBC440 : 18000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075362] FFFBC460 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075370] FFFBC480 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075378] FFFBC4A0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075386] FFFBC4C0 : 18000000 00000000 18000000 00000000 40000006 FFFFF090
[294019.075400] User Command Buffer: 40000051, FFFBC4F8 PID:822 Xorg
[294019.075409] FFFBC4F8 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.075418] FFFBC518 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.075426] FFFBC538 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.075434] FFFBC558 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.075444] FFFBC578 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 0004049F
[294019.075452] FFFBC598 : 002404B5 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.075460] FFFBC5B8 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 000404A4
[294019.075471] FFFBC5D8 : 00200016 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.075479] FFFBC5F8 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.075487] FFFBC618 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.075495] FFFBC638 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 0004049F 002404B5
[294019.075505] FFFBC658 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.075513] FFFBC678 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.075521] FFFBC698 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.075530] FFFBC6B8 : 18000000 00000701 18000000 00000701 18000000 00000000 18000000 00000000
[294019.075538] FFFBC6D8 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075546] FFFBC6F8 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075553] FFFBC718 : 18000000 00000000 18000000 00000000 18000000 FFFFF7C8 18000000 00000000
[294019.075561] FFFBC738 : 18000000 00000000 18000000 00000000 18000000 00000000 40000002 FFFFF0F0
[294019.075575] User Command Buffer: 40000051, FFFBC778 PID:822 Xorg
[294019.075583] FFFBC778 : 08010E00 00000001 0803048A 5A900000 00001400 00000500 080104E8 00000500
[294019.075592] FFFBC798 : 08010E03 00000008 080104AD 00000320 080104AF FFFFFDC7 080104E7 00000000
[294019.075599] FFFBC7B8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
[294019.075610] FFFBC7D8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
[294019.075618] FFFBC7F8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 08020498 00040483
[294019.075626] FFFBC818 : 00240494 00000000 080204BA FFFFFFFF FFFFFFFF 00000000 080104B5 00000000
[294019.075635] FFFBC838 : 080104B6 FFFFF6FF 08010497 0030CCCC 080104B3 00000000 08020484 0004048E
[294019.075643] FFFBC858 : 00200011 00000000 08014A60 00000500 080104C0 00000000 08040480 5A900000
[294019.075652] FFFBC878 : 00001400 00000500 06000006 00000000 08010E03 00000008 080104AE 00000320
[294019.075660] FFFBC898 : 080104AF FFFFFEF8 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000
[294019.075670] FFFBC8B8 : 080104AF FFF44FFF 0801048D A0002006 20000100 FFFFFF64 00040483 00240494
[294019.075677] FFFBC8D8 : 08010001 00000000 08010001 00000000 08010001 00000000 08010E03 00000008
[294019.075688] FFFBC8F8 : 08010E02 00000701 48000000 00000701 08010E03 00000008 08010E02 00000701
[294019.075696] FFFBC918 : 48000000 00000701 18000000 00000701 18000000 00000701 18000000 00000008
[294019.075704] FFFBC938 : 18000000 00000701 18000000 00000701 18000000 00000000 18000000 00000000
[294019.075711] FFFBC958 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075719] FFFBC978 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
[294019.075727] FFFBC998 : 18000000 00000000 18000000 00000000 18000000 FFFFE4A0 18000000 00000000
[294019.075739] FFFBC9B8 : 18000000 00000000 18000000 00000053 18000000 0000017F 40000008 FFFFF140
[294019.075747] **************************
[294019.075752] *** EVENT STATE DUMP ***
[294019.075756] **************************
[294019.075761] Unsumbitted Event:
[294019.075765] Untriggered Event:
[294019.075769] [0]:
[294019.075776] [1]:
[294019.075780] [2]:
[294019.075784] [3]:
[294019.075788] [4]:
[294019.075792] [5]:
[294019.075796] [6]:
[294019.075801] [7]:
[294019.075806] [8]:
[294019.075810] [9]:
[294019.075815] [10]:
[294019.075819] [11]:
[294019.075824] [12]:
[294019.075828] [13]:
[294019.075832] [14]:
[294019.075837] [15]:
[294019.075841] [16]:
[294019.075845] [17]:
[294019.075849] [18]:
[294019.075854] [19]:
[294019.075858] [20]:
[294019.075862] [21]:
[294019.075867] [22]:
[294019.075871] [23]:
[294019.075875] [24]:
[294019.075880] [25]:
[294019.075884] [26]:
[294019.075889] gcvHAL_COMMIT_DONE
[294019.075894] [27]:
[294019.075900] gcvHAL_SIGNAL process=17 signal=0x336
[294019.075905] [28]:
[294019.075910] Number of Pending Interrupt: 2
[294019.075916] INTR_ACKNOWLEDGE=0x0
[294019.075920] Notify State=-1
[294019.075925] Pending=0x0
[294019.075934] **************************
[294019.075938] *** PROCESS DB DUMP ***
[294019.075942] **************************
[294019.075947] PID NAME
[294019.075954] 1942 systrayd
[294019.075960] 822 Xorg
[294019.075965] 1462 autoffd
[294019.075972] 1945 ctrlpanelgui
[294019.075977] 1421 shutdownd
[294019.075983] 1711 desktopPanel
[294019.075990] [galcore]: Stop driver to keep scene.
