Audio play issue through GUI
yashavanthashet
Contributor V
I am using Android pie 9.0 release in our custom board.
Here I am facing a issue related to audio.
I can play audio using tinyplay command, but if I  try to play any audio file through GUI using music app, it closes immediately.
If i try to play any video using gui with any app, it pauses with very first frame, doesn't move further. I have attached logcat output here.
Kindly let me know if anyone has faced this.
Thanks in advance,
Yashavantha
diegoadrian
Which i.MX are you using?
Diego.
yashavanthashet
Contributor V
I am using i.MX8.
Issue solved after updating sample rate in android_configuration.xml file.
Yashavantha
zhengguang_yang
Hi Yashavantha:
How do you fix this bug? I have the same problem.
Thank you very much.
