hi all,
I have a FRDM k64 board, and I want to practice Mbed projects on my board. the problem is when I connect the board to the PC simply and also connect it by reset button pressed both shows maintenance mode. what should i do to work it normally? anyone please help?
Hi ANJU,
It seems you FRDM board only has MBED bootloader, but hasn't debug application. Please download application from OpenSDA Serial and Debug Adapter | NXP . Then just copy the firmware to 'maintenance'. You can select one of CMSIS-DAP/P&E/Jlink.
Jing
