MK10DX256VMC7 JTAG Clock max frequency
gshankara
What is the maximum TCK frequency on MK10DX256VMC7 ?
Thank you.
kerryzhou
Hi Gurushankar Ramamurthy,
   You are welcome!
   Next time, when you check the datasheet's data, you can go to the nxp official website find the newest datasheet at first.
   If your question is solved, please help me to mark the correct answer, just to close this case, thank you!
Kerry
gshankara
Thank you very much, Kerry. For some reason, when I did a search in the datasheet earlier I could not find this info.   I downloaded the datasheet again. Sure enough, I can find that. Appreciate your help.
kerryzhou
   You are welcome!
Kerry
kerryzhou
Hi Gurushankar Ramamurthy ,
   Please check the MK10DX256VMC7 datasheet:
Wish it helps you!
Kerry
