i.MXRT QSPI boot
i.MXRT QSPI boot
sugiyamatoshihi
Contributor V
I have a question about QSPI boot of i.MXRT1050.
I checked Table 8-9. Fuse definition for Serial NOR over FlexSPI in reference manual, rev2 .
There is BOOT_CFG2[2:0] Device selection and QSPI description is only 111b column.
Does it support QSPI by only BOOT_CFG2[2:0] =111?
Does other BOOT_CFG2[2:0] =000 and 001 support for Single SPI mode?
Sugiyama
jingpan
000b- NOR QSPI flash which has 3 byte address read
001b- NOR QSPI flash which has 4 byte address read
Jing
jingpan
Jing
sugiyamatoshihi
Contributor V
Hi, Jing,
Thank you for your answer.
I understood.
Sugiyama
