S32K144 FLASH read
S32K144 FLASH read
zimoonru
Hi,all.
    I'm using S32K144 for my project. I want to use the on chip FLASH to store data,but I don't want to using it as an EEPROM because my bootloader is using FLASH.
   I found the API of write FLASH in SDK: FLASH_DRV_Program(), but I can not find the read API.And I can not  find any description and command of FLASH read in reference manual.
  My question is : How can I read the FLASH data IF I do not use it as EEPROM ?
   Waiting for reply!
   Regards!
danielmartynek
I understand you want to use the FlexNVM as DFlash.
There is no API as you mentioned.
You can read the DFlash data simply with a pointer.
BR, Daniel
