S32k144 not detecting analog input
Question asked by Bao Anh Nguyen on Mar 19, 2019
Latest reply on Mar 20, 2019 by Constantin Razvan Chivu
I am currently trying to make the S32K144 board to recognize an external analog signal in addition to multiple analog signals. (multiple sensors application)
I am running a 5-0V signal from a power supply to the NXP analog pins + potentiometer reading to see if my model can recognize multiple analog signals. However, I only obtain 2 readings of the NXP potentiometer and everything else is 0.
The algorithm should work as two independent readings of the potentiometer (analog) are working fine (with 2 separate memory slots in ADC).
I have attached the model below, including a FreeMaster file.
Thank you
