imxrt1050 Flexcan Polling, FIFO and Masking
Question asked by Michael Smorto on Mar 17, 2019
Latest reply on Mar 19, 2019 by jeremyzhou
I have been working with Flexcan on the imxrt1050 and the interrupt examples works with no problem.  Also modified it to work so it receives and transmits with out interrupts but still uses the same basic masking and setup for tx and rx.
Now I have a three part question:
1.  Do you have any examples for setting up flexcan for polling mode?
2.  Do you have any examples for setting up flexcan in fifo mode?
3.  Masking set up is confusing the heck out of me.  For instance how to do you set the mask up in any of the modes to accept any msg.id?  Especially since it is also driven by "    FLEXCAN_SetRxMbConfig(EXAMPLE_CAN, RX_MESSAGE_BUFFER_NUM, &mbConfig, true);"  So what would this be to receive any msg.
Thanks in advance.
Mike
