FLASH Driver
FLASH Driver
harshitha_chiga
I am downloading the CAN Communication Application Stack  using Flash Bootloader in MC9S12XEA100.
It is mentioned that Flash Bootloader downloads the Flash Driver in RAM and this helps in downloading the application in the memory.
I am doing all this is a Tool.
What my question is how exactly the Flash Driver is doing this? What does it has?
NOTE: Flash Driver is provided by SIP.
Thanks and Regards,
Harshitha
lama
we are very sorry but we are not able to identify what product you exactly use.
The only what is clear is device.
CAN Communication Application Stack ???
NOTE: Flash Driver is provided by SIP. ... SIP is Company or System in package?
Could you please refine question to be absolutely sure what is you question related to?
best regards,
Ladislav
