How to use the automatic address detection for SC16IS740, SC16IS750, SC16IS760
mikami
Hi,there.
I need to fix the issue the following,
How to use the automatic address detection for SC16IS740, SC16IS750, SC16IS760?
I'm not sure about the method.
I've made the following list.
UART_REG_LCR <= 0xBF
UART_REG_XOFF2 <= hwid
UART_REG_EFR <= 0x20
UART_REG_LCR <= 0x00
But it's doesn't work.
Please let me know if Y have any advises.
Best
Masa
Labels (4)
guoweisun
Can you help and confirm below information when you implement ADT function?
1: what is the value about EFCR[0]?
2:can you check IER bit 2 value?
3: double check your hwid
Additional I attached the app note about ADT function introduce.
Thanks!
mikami
Hi,Thanks.
→ Now I'm trying to set it at 0x30. but Is It wrong?
   The Answer is 0x31 right?
→IER bit 2 is [1].
Ok.I see.
Kindly regarads
Masa
guoweisun
Yes,you can set EFCR as 0X31 to try again!
