how to set systick to get microsecond(us) delay in use s32k144
jinshuaixu
Contributor V
hello
        S32DS software has the  delay function.the example project that s32ds provide is millisecond(ms) delay "OSIF_TimeDelay(1)", now I want to use microsecond(us) delay ,how l acquire this function ,please help me if you know how to configuration register or give me example project. thank you.
danielmartynek
The OSIF implementation can be found in the osif_baremetal.c file.
The reload value of the SysTick is the core frequency divided by 1000, that means that the Systick interrupt is called every 1ms and increment the s_osif_tick_cnt counter.
The counter is then read and compered by the OSIF_TimeDelay() function.
If the core frequency was divided by 10000, the counter would increment every 100us (OSIF_TimeDelay(1) = 100us).
The SysTick description can be found in ARM documentation.
Cortex™-M4 Devices Generic User Guide
Section 4.4 System timer, SysTick
Eashwar
Hi Daniel,
I also have the same requirement to generate microsecond delay, but my Controllers is MPC5777C. OSIF is connected to PIT(default) and its frequency is 100MHz. I have also followed your instructions and updated divider value in "static inline void osif_UpdateTickConfig(void)" function, as shown in image below.
The problem is when I call "OSIF_TimeDelay(1)" program pointer is struck in  "osif_Tick()".
Kindly provide suitable solution.
Eashwar
danielmartynek
Eashwar
Hi Daniel,
Eashwar
jinshuaixu
Contributor V
thank you for you response, l have test the way you you offer,the result is correct.
