FUSION FREQUENCY
Question asked by Giovanni Grondona on Mar 13, 2019
Latest reply on Mar 20, 2019 by Lisette Paulina Lozano Gomez
I am using SENSOR FUSION Library ver 7.0 with FXOS8700 sensor and the algorithm I do intend to use is compass with tilt compension.
I need to run FUSION ALGORITHM at a very low frequency ( 2 HZ) because of consumption issue The sensor reading routines run at faster speed (about about 8 HZ).
I'd like to know if algorithm can work at low speed ( 2HZ)
Thank you
Giovanni Grondona
