I am working on a design with the Kinetis KV5 microcontroller. The software is written using the NXP model based design toolbox which uses RAppID for the download of the application in the microcontroller.
Is it possible to use the MCU bootloader with a RAppID host application?
Matteo
No its not possible to do that, since both are quite different to use them at the same time,
since the MCU bootloader spect different files than RAppID.
Aldo
