Can the timing parameter of IPU CSI be adjusted by programming?
flagbee
I'm working on making ov5642 8bit parallel camera using i.MX 6Quad.
There are no issues right now but I just wonder how can I adjust the timing parameter of data lines.
I've already read the datasheet of i.MX 6Quad(Table 59. Sensor Interface Timing Characteristics), but I could not get any information.
How can I compensate the timing error by programming?
Hi Jeonghun
there are no ways to compensate timing errors by programming, so it is necessary
in hardware to comply with  timings.
