Can UART/eSCI and CAN interface be tested with daughter board MPC5777c 516DS
vignesh_v
Can UART/eSCI and CAN interface be tested with daughter board MPC5777c 516DS for basic functionality message transfer as im purchasing only daughter board right now?
vignesh_v
hi,
   Thanks One more clarification. As i understand CAN interface when compared to motherboard only one  CAN Module (FlexCAN)is present and hence transferring between one can module to another is not possible right ? loop back needs to be done? please correct me if I'm wrong.
Vignesh
PetrS
Yes, you are right.
Theoretically you can do parallel connection of 2 FlexCAN modules, but connection to second module is almost impossible on this daughter card.
BR, Petr
vignesh_v
And Does Same Apply to SPI because that also only one interface present in daughter board
PetrS
yes.
PetrS
yes, both UART/eSCI and CAN interface are available on the MPC5777C daughtercard.
BR, Petr
