Sensor MMA8451 and Hardware Choice
Question asked by Luigi Sechi on Mar 12, 2019
Latest reply on Mar 12, 2019 by CarlosCasillas
Goodmornig,
I have an hardware question.
I'm using the sensor mma8451 with a datarate of 800Hz and a Raspberry Pi 2B with a quad-core  CPU 900MHz and RAM 1GB. Could be enough right? So why I don't have 800 samples every second? (I have only 200 samples per second)
Is it a bus problem? Should I use the 2 bus in parallel on the same sensor?
Thank you in advance
Luigi
