I have an issue trying to initialize the SD Card using FatFs. Please see attached code.
I have enabled FatFs, SDMMC, and flexio in my SDK manager (V2.4.2 SDK). I did enable SD Card support via SD_DISK_ENABLE in ffconf.h.
I am getting several errors with the SDMMCHOST calls not being defined. The IDE is definitely seeing them if I right click and open declaration. If I comment out these errors, my code crashes when I try to mount the SD Card.
Has anyone else seen these issues before? I'm sure it will probably be a settings issue, but I'm just not sure where.
-Mike
