We just started using the MCIMX6Q-SDB evaluation kit. I would like to know how to configure it from imx6Quad to imx6Dual or imx6Solo in software? Thanks.
Shu
Solved! Go to Solution.
Hi Shu
dual can be configured with "maxcpus=2" as described in Table 11. Common kernel boot parameters
attached Release Notes. Also for building image one can select appropriate configuration
(for example imx6solosabresd) described in sect.5.1 Build configurations
attached Yocto Guide. Also one can look at sect.5 Enabling Solo Emulation attached Linux Guide.
Hi Shu
